Hello to everyone.
I have a really weird thing going on here and I'd like to ask for some help.
The problem is as follows:
I have a home ADSL Internet Connection of up to 24 Mbps for Download and up to 1 Mbps for Upload. I know that these are really lame internet speeds but in my country that is the best possible speed for simple ADSL connections. Considering all the noise and connectivity loss, I would be happy if I had 14 Mbps of download and 0.7 Mbps of Upload Speed.
The problem is that though my average upload speed is as it should be (0.73 Mbps), my download speed is VERY LOW (6.99 Mbps)!
A network technician was sent from my ISP at home to measure my Internet Connection and found out that my Ethernet cable has an Internet Speed of 14 Mbps BEFORE it connects to my ASUS ADSL AC68U Router. After it connects to my Router, the Internet Speed drops at 6. 99 Mbps.
So he told me that the problem is my router. I give you screenshots of the firmware Version of my Router. I think it's upgraded down to the last uploaded version existing in the official asus website.
I tried to enable Adaptive QoS and tested EVERY possible setting there hoping to solve the problem, but to no avail.. Both Adaptive QoS and Traditional QoS did nothing for me. I tested with many values both upload and download speed.
Upload seems to work pretty fine. If I insert low values, the results displayed in https://www.speedtest.net corresponds. The same thing happens with high values (value 1 being the highest since my ISP gives me Upload Speed UP TO 1 Mbps and no more.). So Upload works just fine.
When it comes to Download speed, when I enter values UP TO 7Mbps to QoS, all values also correspond to the result displayed in https://www.speedtest.net. HOWEVER, if I enter values HIGHER than 7 Mbps (e.g. 8 Mbps or 12 Mbps or 24 Mbps), then https://www.speedtest.net acts as if no change has been made and still gives me results not higher than 7 Mbps of Download..
I tried to locate if there is a problem INSIDE the configuration of my Router, and found out that the Data Rate of the Downstream Line Stat is set at 8288 kbps and NEVER changes. I tried to find a menu inside the Router to edit it, but none exists. Is this the source of the problem?
What should I do to fix it??
Thank you all in advance even for reading this
