Hey guys,
I hope, that I posted this in a right section, if not, I do apologize.
as the title states, I've got this modem/router combo. My previous modem/router was Comtrend VR-3026e (internal antenna, basic stuff from the ISP, which is O2).
I wanted to buy some higher end model, because wi-fi connection from Comtrend was terrible, so I moved onto Asus one and wi-fi improvement was night and day difference. (before it I tried extenders etc. but it did not work well)
Problem: In a totally random times, it drops the connection, it does not last for more than 30 sec. I will post you system log:
Drop times: 00:20:40, 00:21:20, 11:38:19, 13:12:57, 13:13:42, 13:55:29, 14:55:58, 15:42:10, 18:49:17
Also: I called to my ISP, provided him my system log with times, when the connection was lost and I was told that there is nothing in their log, that the connection is perfectly stable. I called there twice on a different occasions.
Since I am total newbie, when it comes to the networking, I wonder, if here is anyone willing to help me. For now, I tried to reconnect old comtrend.
- Jan 24 00:02:30 miniupnpd[13061]: upnp_event_process_notify: connect(192.168.1.39:2869): Connection timed out
- Jan 24 00:20:40 WAN Connection: Ethernet link down.
- Jan 24 00:20:40 stop_nat_rules: apply the redirect_rules!
- Jan 24 00:21:15 WAN Connection: WAN was restored.
- Jan 24 00:21:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 00:21:17 pppd[488]: Serial link appears to be disconnected.
- Jan 24 00:21:17 pppd[488]: Connection terminated.
- Jan 24 00:21:20 WAN Connection: Fail to connect with some issues.
- Jan 24 00:21:20 stop_nat_rules: apply the redirect_rules!
- Jan 24 00:21:27 pppd[488]: Connected to 00:30:88:1d:ff:dc via interface vlan100
- Jan 24 00:21:27 pppd[488]: Connect: ppp0 <--> vlan100
- Jan 24 00:21:27 pppd[488]: PAP authentication succeeded
- Jan 24 00:21:27 pppd[488]: peer from calling number 00:30:88:1D:FFC authorized
- Jan 24 00:21:27 pppd[488]: local IP address
- Jan 24 00:21:27 pppd[488]: remote IP address
- Jan 24 00:21:27 pppd[488]: primary DNS address
- Jan 24 00:21:27 pppd[488]: secondary DNS address
- Jan 24 00:21:27 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 00:21:28 wan: finish adding multi routes
- Jan 24 00:21:28 rc_service: ip-up 14736:notify_rc stop_upnp
- Jan 24 00:21:28 rc_service: ip-up 14736:notify_rc start_upnp
- Jan 24 00:21:28 rc_service: waitting "stop_upnp" via ip-up ...
- Jan 24 00:21:28 miniupnpd[13061]: shutting down MiniUPnPd
- Jan 24 00:21:29 ntp: start NTP update
- Jan 24 00:21:30 miniupnpd[14768]: version 1.9 started
- Jan 24 00:21:30 miniupnpd[14768]: HTTP listening on port 36841
- Jan 24 00:21:30 miniupnpd[14768]: Listening for NAT-PMP/PCP traffic on port 5351
- Jan 24 00:21:30 WAN Connection: WAN was restored.
- Jan 24 00:59:57 ntp: start NTP update
- Jan 24 01:59:59 ntp: start NTP update
- Jan 24 03:00:01 ntp: start NTP update
- Jan 24 03:59:57 ntp: start NTP update
- Jan 24 04:59:57 ntp: start NTP update
- Jan 24 05:59:59 ntp: start NTP update
- Jan 24 06:59:57 ntp: start NTP update
- Jan 24 07:59:57 ntp: start NTP update
- Jan 24 08:59:59 ntp: start NTP update
- Jan 24 10:00:01 ntp: start NTP update
- Jan 24 10:59:57 ntp: start NTP update
- Jan 24 11:38:19 WAN Connection: Ethernet link down.
- Jan 24 11:38:19 stop_nat_rules: apply the redirect_rules!
- Jan 24 11:38:43 WAN Connection: WAN was restored.
- Jan 24 11:38:43 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 11:59:59 ntp: start NTP update
- Jan 24 13:00:01 ntp: start NTP update
- Jan 24 13:12:57 WAN Connection: Ethernet link down.
- Jan 24 13:12:57 stop_nat_rules: apply the redirect_rules!
- Jan 24 13:13:32 WAN Connection: WAN was restored.
- Jan 24 13:13:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 13:13:41 pppd[488]: Serial link appears to be disconnected.
- Jan 24 13:13:41 pppd[488]: Connection terminated.
- Jan 24 13:13:42 WAN Connection: Fail to connect with some issues.
- Jan 24 13:13:42 stop_nat_rules: apply the redirect_rules!
- Jan 24 13:13:52 pppd[488]: Connected to 00:30:88:1d:ff:dc via interface vlan100
- Jan 24 13:13:52 pppd[488]: Connect: ppp0 <--> vlan100
- Jan 24 13:13:52 pppd[488]: PAP authentication succeeded
- Jan 24 13:13:52 pppd[488]: peer from calling number 00:30:88:1D:FFC authorized
- Jan 24 13:13:52 pppd[488]: local IP address
- Jan 24 13:13:52 pppd[488]: remote IP address
- Jan 24 13:13:52 pppd[488]: primary DNS address
- Jan 24 13:13:52 pppd[488]: secondary DNS address
- Jan 24 13:13:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 13:13:52 wan: finish adding multi routes
- Jan 24 13:13:57 WAN Connection: WAN was restored.
- Jan 24 13:13:58 rc_service: ip-up 19689:notify_rc stop_upnp
- Jan 24 13:13:58 rc_service: ip-up 19689:notify_rc start_upnp
- Jan 24 13:13:58 rc_service: waitting "stop_upnp" via ip-up ...
- Jan 24 13:13:58 miniupnpd[14768]: shutting down MiniUPnPd
- Jan 24 13:13:59 ntp: start NTP update
- Jan 24 13:13:59 miniupnpd[19721]: version 1.9 started
- Jan 24 13:13:59 miniupnpd[19721]: HTTP listening on port 38142
- Jan 24 13:13:59 miniupnpd[19721]: Listening for NAT-PMP/PCP traffic on port 5351
- Jan 24 13:39:20 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
- Jan 24 13:39:21 kernel: sizeof forward param = 160
- Jan 24 13:39:36 kernel: Stop the IPS/AppID engine...
- Jan 24 13:39:37 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 13:39:57 rc_service: httpd 438:notify_rc start_webs_update
- Jan 24 13:55:29 WAN Connection: Ethernet link down.
- Jan 24 13:55:29 stop_nat_rules: apply the redirect_rules!
- Jan 24 13:55:45 WAN Connection: WAN was restored.
- Jan 24 13:55:45 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 13:59:57 ntp: start NTP update
- Jan 24 14:55:58 WAN Connection: Ethernet link down.
- Jan 24 14:55:58 stop_nat_rules: apply the redirect_rules!
- Jan 24 14:56:23 WAN Connection: WAN was restored.
- Jan 24 14:56:23 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 14:59:57 ntp: start NTP update
- Jan 24 15:42:10 WAN Connection: Ethernet link down.
- Jan 24 15:42:10 stop_nat_rules: apply the redirect_rules!
- Jan 24 15:42:51 pppd[488]: Serial link appears to be disconnected.
- Jan 24 15:42:56 WAN Connection: Fail to connect with some issues.
- Jan 24 15:42:57 pppd[488]: Connection terminated.
- Jan 24 15:42:58 pppd[488]: Modem hangup
- Jan 24 15:43:44 pppd[488]: Timeout waiting for PADS packets
- Jan 24 15:43:49 pppd[488]: Connected to 00:30:88:1d:ff:dc via interface vlan100
- Jan 24 15:43:49 pppd[488]: Connect: ppp0 <--> vlan100
- Jan 24 15:43:49 pppd[488]: PAP authentication succeeded
- Jan 24 15:43:49 pppd[488]: peer from calling number 00:30:88:1D:FFC authorized
- Jan 24 15:43:49 pppd[488]: local IP address
- Jan 24 15:43:49 pppd[488]: remote IP address
- Jan 24 15:43:49 pppd[488]: primary DNS address
- Jan 24 15:43:49 pppd[488]: secondary DNS address
- Jan 24 15:43:49 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 15:43:50 wan: finish adding multi routes
- Jan 24 15:43:50 rc_service: ip-up 20868:notify_rc stop_upnp
- Jan 24 15:43:50 rc_service: ip-up 20868:notify_rc start_upnp
- Jan 24 15:43:50 rc_service: waitting "stop_upnp" via ip-up ...
- Jan 24 15:43:50 miniupnpd[19721]: shutting down MiniUPnPd
- Jan 24 15:43:50 WAN Connection: WAN was restored.
- Jan 24 15:43:51 ntp: start NTP update
- Jan 24 15:43:51 miniupnpd[20900]: version 1.9 started
- Jan 24 15:43:51 miniupnpd[20900]: HTTP listening on port 50603
- Jan 24 15:43:51 miniupnpd[20900]: Listening for NAT-PMP/PCP traffic on port 5351
- Jan 24 15:59:57 ntp: start NTP update
- Jan 24 16:59:57 ntp: start NTP update
- Jan 24 17:59:57 ntp: start NTP update
- Jan 24 18:49:17 WAN Connection: Ethernet link down.
- Jan 24 18:49:17 stop_nat_rules: apply the redirect_rules!
- Jan 24 18:49:52 WAN Connection: WAN was restored.
- Jan 24 18:49:52 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_vlan100)!
- Jan 24 18:59:57 ntp: start NTP update
