ASUS DSL-AC68U - Mobile connected to Wireless 5g keeps disconnecting and reconnecting
Saadi
Hey guys,
I'm from New Zealand. Got gigabit fibre connection and setup using my DSL-AC68U and VOIP with same internet provider setup through Grandstream HT802.
Everything's running smooth as far as I can tell except one issue I'm constantly having - My mobile phone Oneplus 6t which is connected to the 5ghz band of the router keeps dropping connection and reconnecting. In the router's log I see the following -
Jan 18 14:45:56 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 14:45:57 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 14:45:57 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 14:50:41 rc_service: dhcp6c 25351:notify_rc restart_ddns
Jan 18 14:55:41 rc_service: dhcp6c 25893:notify_rc restart_ddns
Jan 18 14:58:56 acsd: selected channel spec: 0x1003 (3)
Jan 18 14:58:56 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 14:58:56 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_CSTIMER
Jan 18 15:00:41 rc_service: dhcp6c 26459:notify_rc restart_ddns
Jan 18 15:05:41 rc_service: dhcp6c 27018:notify_rc restart_ddns
Jan 18 15:06:36 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 15:06:40 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 15:06:40 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 15:10:41 rc_service: dhcp6c 27578:notify_rc restart_ddns
Jan 18 15:14:01 acsd: selected channel spec: 0x1003 (3)
Jan 18 15:14:01 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 15:14:01 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_CSTIMER
Jan 18 15:15:41 rc_service: dhcp6c 28138:notify_rc restart_ddns
Jan 18 15:20:41 rc_service: dhcp6c 28694:notify_rc restart_ddns
Jan 18 15:25:41 rc_service: dhcp6c 29248:notify_rc restart_ddns
Jan 18 15:29:05 acsd: selected channel spec: 0x1005 (5)
Jan 18 15:29:05 acsd: Adjusted channel spec: 0x1005 (5)
Jan 18 15:29:05 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Jan 18 15:30:41 rc_service: dhcp6c 29804:notify_rc restart_ddns
Jan 18 15:35:41 rc_service: dhcp6c 30365:notify_rc restart_ddns
Jan 18 15:40:41 rc_service: dhcp6c 30918:notify_rc restart_ddns
Jan 18 15:44:08 acsd: selected channel spec: 0x1003 (3)
Jan 18 15:44:08 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 15:44:08 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_CSTIMER
Jan 18 15:45:41 rc_service: dhcp6c 31472:notify_rc restart_ddns
Jan 18 15:50:41 rc_service: dhcp6c 32029:notify_rc restart_ddns
Jan 18 15:52:32 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 15:52:36 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 15:52:36 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 15:55:41 rc_service: dhcp6c 32591:notify_rc restart_ddns
Jan 18 15:59:12 acsd: selected channel spec: 0x1005 (5)
Jan 18 15:59:12 acsd: Adjusted channel spec: 0x1005 (5)
Jan 18 15:59:12 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Jan 18 16:00:42 rc_service: dhcp6c 702:notify_rc restart_ddns
Jan 18 16:05:42 rc_service: dhcp6c 1293:notify_rc restart_ddns
Jan 18 16:10:42 rc_service: dhcp6c 1848:notify_rc restart_ddns
Jan 18 16:10:58 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 16:11:02 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:11:02 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:14:16 acsd: selected channel spec: 0x1003 (3)
Jan 18 16:14:16 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 16:14:16 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_CSTIMER
Jan 18 16:15:42 rc_service: dhcp6c 2409:notify_rc restart_ddns
Jan 18 16:20:42 rc_service: dhcp6c 2959:notify_rc restart_ddns
Jan 18 16:24:09 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 16:24:13 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:24:13 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:25:42 rc_service: dhcp6c 3519:notify_rc restart_ddns
Jan 18 16:29:20 acsd: selected channel spec: 0x1005 (5)
Jan 18 16:29:20 acsd: Adjusted channel spec: 0x1005 (5)
Jan 18 16:29:20 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Jan 18 16:30:42 rc_service: dhcp6c 4079:notify_rc restart_ddns
Jan 18 16:34:14 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 16:34:17 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:34:17 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:35:42 rc_service: dhcp6c 4639:notify_rc restart_ddns
Jan 18 16:40:42 rc_service: dhcp6c 5188:notify_rc restart_ddns
Jan 18 16:44:18 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 16:44:21 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:44:21 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:44:24 acsd: selected channel spec: 0x1005 (5)
Jan 18 16:44:24 acsd: Adjusted channel spec: 0x1005 (5)
Jan 18 16:44:24 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
Jan 18 16:45:42 rc_service: dhcp6c 5750:notify_rc restart_ddns
Jan 18 16:50:42 rc_service: dhcp6c 6305:notify_rc restart_ddns
Jan 18 16:54:25 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 16:54:29 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:54:29 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 16:55:42 rc_service: dhcp6c 6862:notify_rc restart_ddns
Jan 18 16:59:29 acsd: selected channel spec: 0x1003 (3)
Jan 18 16:59:29 acsd: Adjusted channel spec: 0x1003 (3)
Jan 18 16:59:29 acsd: acs_set_chspec: 0x1003 (3) for reason APCS_CSTIMER
Jan 18 17:00:42 rc_service: dhcp6c 7427:notify_rc restart_ddns
Jan 18 17:04:31 syslog: wlceventd_proc_event(491): eth2: Deauth_ind 8E:FD:D0:94:CF:60, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 18 17:04:34 syslog: wlceventd_proc_event(527): eth2: Auth 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 17:04:34 syslog: wlceventd_proc_event(556): eth2: Assoc 8E:FD:D0:94:CF:60, status: Successful (0), rssi:0
Jan 18 17:05:42 rc_service: dhcp6c 7988:notify_rc restart_ddns
Jan 18 17:10:42 rc_service: dhcp6c 8539:notify_rc restart_ddns
Jan 18 17:14:33 acsd: selected channel spec: 0x1005 (5)
Jan 18 17:14:33 acsd: Adjusted channel spec: 0x1005 (5)
Jan 18 17:14:33 acsd: acs_set_chspec: 0x1005 (5) for reason APCS_CSTIMER
The full log list is much larger. This is an excerpt covering repeated errors I can see.
The device 8E:FD:D0:94:CF:60 is my Oneplus 6T I've confirmed. Mum's got a Oneplus Nord but I can't see that anywhere in the log list. I also don't notice any visible issues on my PC connected via Ethernet cable. I haven't experienced any connection drops on PC.
The list also shows an error related to restarting DDNS, but I'm not using DDNS (DDNS client is disabled under WAN settings).
I've tried forgetting WIFI connection on my phone and reconnecting. Also turned off "intelligent network connection" & "intelligently select best wifi".
There is one thing I noticed - in router's System Log > Ipv6 I can see my Oneplus 6T in the Ipv6 LAN device list along with my PC. Can't see the Oneplus Nord or any other devices there. Not sure if that has something to do with it?
If anyone can help guide me to get things running smoothly, it would be great!
Thank you
Saadi
It's very common to see this behaviour from mobile devices when they are in sleep mode. Notice how for the most part the messages are exactly 10 minutes apart. This is typical of the mobile waking up to check for notifications, updates, etc. So unless it's happening while you're actively using the device I'd say it's probably normal.
The repeating DDNS message is a bug that has been reported on other Asus routers. For example here. It only seems to occur when IPv6 is enabled on the router.
Thanks Collin (Part of the Furniture) :D
The drops were happening even when actively using the phone. Would literally see WIFI logo disappear and wait for a second or two then connect to 4G network then connect back to WIFI, meanwhile the webpage or video or whatever would refresh.
On the DHCP Server I gave my phone a static IP. I haven't noticed any WIFI drops on my phone since (it's been less than 24hrs). Will keep an eye out, maybe that fixed the issue...?
Do I need IPv6 for any part of regular internet use (browsing website, streaming videos on youtube, watch anime, download stuff, torrent, gaming etc)? Will it affect internet speed if disabled?
I (like a lot of people) don't have access to IPv6 so it's not an option. I've never found it to be a problem. Whether IPv4 is any better or worse than IPv6 will probably be down to how your ISP has implemented it. You'll have to test it for yourself.
I seem to remember there being similar posts for this particular phone. For example: http://www.snbforums.com/threads/an...s-each-sec-small-interrupts.76592/post-734778
I'll test again Asuswrt RC3 when officially released with IPv6. For now, if you don't need it - Disable.
No.
