Taylordrift21
Hello everyone, I am new to this forum but I would like to ask for some advice if possible.
I recently purchased the Asus DSL-AC68U router a few weeks back to upgrade from my ISP router as the ISP router didn't have any QoS rules or options. I am a regular gamer on console so I needed it mainly for that. From when I got the asus router it was running stock firmware, and I enabled Adaptive QoS with bandwidth limiter manual and I also noticed my ping/latency was lower on my xbox so I was pleased. I thought to begin with it was working but then a few days later I started to get a little lag at times when other devices at home were being used, the main culprit is "Netflix". So I played around with the settings in QoS and found nothing really worked except "Bandwidth Limiter". I can now play the xbox while other people in the house are using Netflix and I don't get the "lag issue". However I did notice my latency has went up on my xbox since. Anyway before I go off track, I upgraded to the Merlin firmware 384.12_gnuton1. So my current settings just now is still on the bandwidth limiter using fq-codel. Which are the better settings to adjust or does the adaptive QoS work fine on this firmware? Any advice available? My problem with using adaptive or traditional even when I adjusted the bandwidth settings for upload and download for priority settings even with the device using netflix and me gaming at the same time was still giving me lag issues. Any help would be appreciated.
