ASUS ET8 Firmware 388_23759
Piggie
After almost a year there is a firmware update for ET8. ASUS ET8 Firmware 388_23759
New features:
1.Plug, Share & Surf: Turn Your ET8 into a 4G/5G Hotspot. Unleash the power of 4G and 5G connectivity without the need for a new router. With your ASUS router and smartphone, you can access high-speed internet instantly. It's as simple as plugging in your phone and sharing its network. Please refer to https://asus.click/AutobackupWAN
2.DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
3.Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
4.Supported WireGuard VPN server and client.
5.Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
6.Supported new devices connection notification.
7.Supported connection diagnostic on the ASUS router app.
8.Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
9.Upgraded parental control and added reward, new scheduler for flexible setting
Security updates:
1.Enabled and supported ECDSA certificates for Let's Encrypt.
2.Allowed binding DDNS to a user's account to reduce the risk of MITM attacks
3.Enhanced protection for credentials.
4.Enhanced protection for OTA firmware updates.
5.Fixed CVE-2023-34359,CVE-2023-34358 Unauthenticated Denial of Service
6.Fixed CVE-2023-34360 Stored XSS
7.Fixed DoS vulnerabilities in firewall configuration pages.
8.Fixed DoS vulerabilities in httpd.
9.Fixed information disclosure vulnerability.
10.Fixed CVE-2023-28702 and CVE-2023-28703.
11.Fixed null pointer dereference vulnerabilities.
12.Fixed the cfg server vulnerability.
13.Fixed the vulnerability in the logmessage function CVE-2023-35086/ CVE-2023-35087.
14.Fixed lighttpd vulnerability, CVE-2023-35720.
15.Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
16.Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
17.Fixed openssl vulnerability, CVE-2023-0464.
18.Fixed ReadyMedia vulnerabilitym CVE-2020-28926.
19.Fixed UPnP vulnerability CVE-2020-12695.
20.Patched a command injection vulnerability to improve overall security.
21.Strengthened protection against SSH brute force attacks.
22.Fixed the cfg server vulnerability.
23.Fixed the vulnerability in the logmessage function.
24..Fixed CVE-2022-46871
25.Fixed Client DOM Stored XSS.
Please unzip the firmware file, and then verify the checksum.
SHA256: 152c72bd808cb03656c32d910cf5e2ffc1e80abefa3c494637240acc107599c7
This firmware finally fixes the Samsung wifi 6e issue. With previous versions, Samsung tablets and phones would not see the wifi 6e signal from the node. They would connect to the router fine but not the node. Many non-Samsung devices were not affected. After this update, my Samsung devices can connect to 6e on the nodes.
New features:
Security updates:
New firmware just came out recently. Have updated to it (for v1.0 hardware). No issues so far (including Ai Mesh). Rebooted twice after firmware update.
Make sure you get the v1.0 or v2.0 update based on your hardware.
Link to new firmware: https://www.asus.com/supportonly/zenwifi et8/helpdesk_bios/
