Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_34810
VANT
Bug Fixes and Enhancements:
1. Strengthened input validation and data processing workflows to further protect information security.
2. Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
3. Enhanced device security through improved buffer handling in connection features.
4. Refined data handling processes, ensuring secure and accurate information management.
5. Enhanced file access control mechanisms, promoting a more secure operating environment.
6. Strengthened certificate protection, providing Enhanced data security.
Avaible from router gui and Asus download page
Even after disabling AI Mesh and deleting my nodes, then doing a factory reset, I can't upgrade firmware. I'm stuck on 3.0.0.6.102_34791 :( (via "check for updates" and upgrading that way, or downloading file from Asus support web site, unzipping, verify checksum, and uploading file from PC)
Any suggestions on how to upgrade to this?
U can try to do a hard factory reset, if that still doesnt work then i think your Router is bad.
https://www.asus.com/support/faq/1039078/
Did You do this ?
Unfortuantely warranty ended June 2024. Unless the credit card I used has any extra protection on it, I guess I'm out of luck.
Your GT-AX6000 is more than 3 years old? Its release date was January 2022...
Not necessarily. The warranty period varies per region and distribution channel.
Example from BestBuy in the US (the same in Canada), GT-AX6000 in particular:
I know some people get 3 years warranty, but this is not the case for everyone.
Interesting as the ASUS US store shows 3-year warranty.
I know. They say 3 years warranty and send you to a local retailer place to purchase it where the warranty may be reduces to 2 years without you noticing. My RT-AX86U was purchased from Canada Computers and the warranty expired after 2 years according to Asus by S/N of the device. 🤷‍♂️
Tried ASUS Firmware Restoration and upgrade from that application?
@Tech9 I thought you were joking about this, so I checked the Asus Website for the expiry of my warranty, and it's several months short of three years. Which is pretty bizarre as I've had it since about a week after launch!
Different warranty conditions for your place.
Product manufactured in 2022 and sold in Canada. Funny the warranty on this one expired 3 days after the last firmware update was released. :)
Okay - cant get to the page that you guys obviously can - instead I get: *Maybe I got this a week or so after my works decided to start selling them.
