Release ASUS GT-AXE11000 Firmware version 3.0.0.4.388.22525
Woymfsu03
73.33 MB
2023/02/13
1.Fixed CVE-2022-46871
2.Fixed Client DOM Stored XSS.
3.Improved AiMesh backhaul stability.
4.Fixed AiMesh topology UI bugs.
5.Fixed the reboot issue when assigning specific clients in VPN fusion.
6.Fixed the VPN fusion bug when importing the Surfshark WireGuard conf file.
7.Fixed network map bugs.
Wow, 4 stream AX on an AX86U! I have two AX86Us and have never got better than two streams.
2-Screenshot 2023-02-15 at 18-58-03 ASUS Wireless Router RT-AX86U Pro - Wireless Log.png
2-Screenshot 2023-02-15 at 19-12-15 ASUS Wireless Router RT-AX86U Pro - General.png
I cleaned up the thread and Woymfsu03 has earned a 1 week ban.
@octopus You should know better than to be baited by trolling.
When will Asus make a real stable version? This version is worse than last one on early Feb? The home network becomes the part of important element in our daily life at home as same as electricity, water & gas! Also, Asus shall provide feedback channel to report the problem and collect statistics. Stability is more important than new features.
Hi, I have the GT-AX11000 upgraded to the FW 3.0.0.4.388.22525 nothing but problems trying to configure the 5-2 ghz profile. any changes would get stuck on saving loop for infinity. I did a hard reset. problem would still persist. Had to back track to the older previous firmware. That is a major bug, there must had been testing before releasing to the public.
I have the same issue
