Release ASUS GT-BE98 Firmware version 3.0.0.6.102_36878 (2024/12/04)
xander73
Version 3.0.0.6.102_36878
69.06 MB 2024/12/04
Please unzip the firmware file, and then verify the checksum.
SHA256: ae96ab1fabf568bd01cf19bc17cba978d36c23c3509cc2b2bfdb002280c807c9
1. Strengthened input validation and data processing workflows to further protect information security.
2. Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
3. Enhanced device security through improved buffer handling in connection features.
4. Refined data handling processes, ensuring secure and accurate information management.
5. Enhanced file access control mechanisms, promoting a more secure operating environment.
6. Strengthened certificate protection, providing enhanced data security.
Huge bug in this firmware. Your guest network is no longer respecting WAN BLOCK on devices. So main wifi network will block as usual if you set it so but guest network WAN block is no longer working. Only solution is go back to former firmware. Tried this with numerous devices, android tv, android mobile phone, ios etc.. the wan block no longer working.
Bummer for such an expensive router.
hopefully fixed asap.
Well done some more testing and the GUEST network has full access to the internet , blocked or not. Send pictures with logs already to asus. For main wifi the wan block is working as intented. For guest networks it's not.
Anyone else has the issue ?
update today :
Even after FULL FACTORY RESET
Even after RESTORE OLDER FIRMWARE
Even after deleting wifi guest networks and re-installing them.
All to no avail, wifi guest networks are disregarding WAN BLOCK.
no problems here, i dont use guest networks on this router but did the test and it more or less ignores it
cheers
Well I did more testing, deleted all guest networks, made a new IoT (internet of things) network , same result. The wan block is not working. You can set it to on for the device, shows red icon , but traffic is visible and just goes trough. Started youtube on a blocked smartphone and on a blocked TV and no problem whatsoever to get internet access.
This firmware is serious bagger, especially for a router of this price.
I will end up sending them back. Buy something else.
