Starlocket
Posting here cuz I've head no luck with Asus support other than requesting to send it in and waiting a few weeks. Trying to figure out whether its a router issue or elsewhere.
Basically the issue is this, randomly at least once (sometimes twice) a day (sometimes can go 1-3 days w/o any issue) the modem will just lose internet access.
We had our cable provider come out and test and say it was initially the modem, but tests w/ it showed nothing wrong, still replaced anyways per their recommendation. Using a motorola (latest can get the model if anyone needs)
Set that up and was back online for a few days before the issue happenned again.
Our setup:
Asus GTAX11000 Router as the main router on AI MESH
GTX?5300 Router as an AP in wired backhaul mode.
Modem connects to the 11000, while the 5300 connects to the 11000 directly (from upstairs (3 floors used to be on the 2nd but moved to the 3rd )
For the rest of the wall jacks in the house we have them going to a switch panel that diverts down via 2 lines to our 11000.
The issue when the router loses internet is that I can't ping or anything, and router says internet has no connection, HOWEVER if I reboot the router, everything is fine.
If I connect directly to the modem itself while the router is down ( unplugging from router and putting directly to laptop ) internet is still working.
I've attempted a factory reset on the devices after to validate but no dice so far.
We're gonna probably order the 16000 to replace the 11000 in the event its bad but trying to get additional insight to see if maybe it could just be a setting within the AI Mesh that I'm missing.
Here's the latest log from when it disconnected , I logged into the router and copy/pasta'd the log before rebooting. Any additional info requests please let me know.
Our setup:
May 12 21:52:09 wlceventd: wlceventd_proc_event(508): eth6: Disassoc C6:58:F6:3A:FD:30, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 12 21:52:09 roamast: [EXAP]Deauth old sta in 0 0: C6:58:F6:3A:FD:30
May 12 21:52:09 roamast: eth6: disconnect weak signal strength station [c6:58:f6:3a:fd:30]
May 12 21:52:09 roamast: eth6: remove client [c6:58:f6:3a:fd:30] from monitor list
May 12 21:52:31 wlceventd: wlceventd_proc_event(508): eth7: Disassoc EE:E1:18:5C:60:86, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 12 21:52:31 roamast: [EXAP]Deauth old sta in 1 0: EE:E1:18:5C:60:86
May 12 21:52:31 roamast: eth7: disconnect weak signal strength station [ee:e1:18:5c:60:86]
May 12 21:52:31 roamast: eth7: remove client [ee:e1:18:5c:60:86] from monitor list
May 12 21:52:34 wlceventd: wlceventd_proc_event(527): eth7: Auth EE:E1:18:5C:60:86, status: Successful (0), rssi:0
May 12 21:52:34 wlceventd: wlceventd_proc_event(537): eth7: ReAssoc EE:E1:18:5C:60:86, status: Successful (0), rssi:-85
May 12 21:52:40 wlceventd: wlceventd_proc_event(508): eth7: Disassoc EE:E1:18:5C:60:86, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
May 12 21:52:42 roamast: [EXAP]Deauth old sta in 1 0: EE:E1:18:5C:60:86
May 12 21:52:42 roamast: eth7: disconnect weak signal strength station [ee:e1:18:5c:60:86]
May 12 21:52:42 roamast: eth7: remove client [ee:e1:18:5c:60:86] from monitor list
May 12 21:52:42 wlceventd: wlceventd_proc_event(527): eth7: Auth EE:E1:18:5C:60:86, status: Successful (0), rssi:0
May 12 21:52:42 wlceventd: wlceventd_proc_event(537): eth7: ReAssoc EE:E1:18:5C:60:86, status: Successful (0), rssi:-80
May 12 21:52:54 roamast: [EXAP]Deauth old sta in 1 0: EE:E1:18:5C:60:86
May 12 21:52:54 roamast: eth7: disconnect weak signal strength station [ee:e1:18:5c:60:86]
May 12 21:52:54 roamast: eth7: remove client [ee:e1:18:5c:60:86] from monitor list
