ASUS IoT network causes loss of internet connection on main network.
d0gg
I have an ASUS GT-AX11000 Pro router setup with 5 Nodes (ASUS ROG GT6) in a AiMesh network with an ethernet backhaul.
Generally my network runs with no issues until I attempt to setup an IoT network using the "Guest Network Pro". The moment I set it up, everything starts dropping from the network and I lose my connection to the internet on the main network. I also lose connection to other devices on the network. All 3 of my NASes un mount from the computers they are connected to.
I never add anything to the IoT network. After the Main router restarts from applying the settings it immediately starts to kill the main network.
The only way I can get things back to normal is to delete the IoT network that was created. Once it is gone, it usually takes about 10-15 minutes and everything is back to normal.
Does anyone have any ideas on what might be going on? What I might need to check on?
Have you done a restore to factory default yet (clear everything)? It usually fix all problems such as this.
From my experience, playing around with the settings too much can cause everything to #$%@ up sometimes where the only way to fix it is to restore to factory default.
Ouch!
No I haven't gone that far.
So far I have added the 5 nodes to the AiMesh and added a bunch of port forwarding. Not much more than that. So I wouldn't think it would have to do with adjusting settings.
Let me see if anyone else has any other ideas, but that will totally be in the option list. I have gone scorched earth on Network issues before.
Do you set up the IoT Guest WIFI with 2.4 and 5 GHz bands? If so, try again with just the 2.4 GHz band. I have had problems with a "Pro" AX router and an AX router with not being able to use both bands in an IoT WIFI. Most of your IoT devices will work just fine on 2.4 GHz. And set the 2.4 GHz to 20 MHz bandwidth.
I think I did set it to 2.4 GHz. But I will run it again and make sure I leave out the 5. Also I have to use a new subnet. The "Guest Network Pro" reports to me that the GT6 Nodes are not capable of using the same subnet. Not sure if that has anything to do with it. I would think that if I had to do anything else it would tell me. But I'm not sure.
Makes sense, sort of. The IoT on my Pro assigns a VLAN of 52 which will propagate to the nodes. The GT6 as nodes are limited in what they can do.
