Entware Asus-Merlin 388.8 GT-AX11000 Entware v2RayA package error
RootX
Thank you very much for your support and development of this software. I have the following question, I installed entware from atmt, then installed the v2rayA package to manage VPN connections, but when I start the connection I see the following error:
failed to start v2ray-core: not support "redirect" mode of transparent proxy: ExecCommands: iptables -w 2 -t nat -N TP_OUT Bad argument `2' Try `iptables -h' or 'iptables --help' for more information. : exit status 2
I also started using amnezia on my vps to create a vpn connection, is it possible to integrate interaction with this product into the firmware? I saw something similar for a regular VPN, if this functionality could be improved example, it would be just perfect!
As of June 10 2025, version 3006.102.4_0 still has the same problem even if the iptables (v1.4.21) does support the -w option. Check the last few lines of the output.
Bash:
xxx@RT-BE88U-6190:/tmp/home/root# iptables -h
iptables v1.4.21
Usage: iptables -[ACD] chain rule-specification [options]
       iptables -I chain [rulenum] rule-specification [options]
       iptables -R chain rulenum rule-specification [options]
       iptables -D chain rulenum [options]
       iptables -[LS] [chain [rulenum]] [options]
       iptables -[FZ] [chain] [options]
       iptables -[NX] chain
       iptables -E old-chain-name new-chain-name
       iptables -P chain target [options]
       iptables -h (print this help information)
Commands:
Either long or short options are allowed.
  --append  -A chain            Append to chain
  --check   -C chain            Check for the existence of a rule
  --delete  -D chain            Delete matching rule from chain
  --delete  -D chain rulenum
                                Delete rule rulenum (1 = first) from chain
  --insert  -I chain [rulenum]
                                Insert in chain as rulenum (default 1=first)
  --replace -R chain rulenum
                                Replace rule rulenum (1 = first) in chain
  --list    -L [chain [rulenum]]
                                List the rules in a chain or all chains
  --list-rules -S [chain [rulenum]]
                                Print the rules in a chain or all chains
  --flush   -F [chain]          Delete all rules in  chain or all chains
  --zero    -Z [chain [rulenum]]
                                Zero counters in chain or all chains
  --new     -N chain            Create a new user-defined chain
  --delete-chain
            -X [chain]          Delete a user-defined chain
  --policy  -P chain target
                                Change policy on chain to target
  --rename-chain
            -E old-chain new-chain
                                Change chain name, (moving any references)
Options:
    --ipv4      -4              Nothing (line is ignored by ip6tables-restore)
    --ipv6      -6              Error (line is ignored by iptables-restore)
[!] --protocol  -p proto        protocol: by number or name, eg. `tcp'
[!] --source    -s address[/mask][...]
                                source specification
[!] --destination -d address[/mask][...]
                                destination specification
[!] --in-interface -i input name[+]
                                network interface name ([+] for wildcard)
 --jump -j target
                                target for rule (may load target extension)
  --goto      -g chain
                              jump to chain with no return
  --match       -m match
                                extended match (may load extension)
  --numeric     -n              numeric output of addresses and ports
[!] --out-interface -o output name[+]
  --table       -t table        table to manipulate (default: `filter')
  --verbose     -v              verbose mode
  --wait        -w              wait for the xtables lock
  --line-numbers                print line numbers when listing
  --exact       -x              expand numbers (display exact values)
[!] --fragment  -f              match second or further fragments only
  --modprobe=<command>          try to insert modules using this command
  --set-counters PKTS BYTES     set the counter during insert/append
[!] --version   -V              print package version.
What else can I try? Q.Q
