I have the following current configuration
The only downside of above configuration I can feel is that since Gargoyle on TP-Link or ASUS RT-ACRH13 are not configured as mesh nodes but as normal access points, the WiFi connection drops and reconnects for a few seconds when moving outside from range of TP-Link or ASUS RT-ACRH13.
If I want to add additional access points (or in future replace one of the non mesh nodes acting as access points), are there any extra benefits of purchasing an economical but new ASUS router and configure it as additional mesh node vis a vis using a spare but more powerful NETGEAR Nighthawk X6 R8000 router available with me as access point.
Thanks and Regards,
esfu
- ASUS RT-AX92U as Main Router (connected to ISP router in double NAT mode)
- ASUS RT-AX92U Mesh node connected via wired backhaul.
- ASUS RT-ACRH13 (no mesh feature) connected as normal access point via wired connection.
- TP-Link TL-WDR3600 v1 with Kibosh Gargoyle OS as normal access point via wired connection.
Thanks and Regards,
esfu
