Does anyone know for certain (like, if you own this, could you measure it for me?) how long the extension cable for the external antenna base is?
On Amazon, someone says it's 100cm, someone says it's 3 ft, someone says it' around 2 ft....another review of the higher model, AC68, says that extension is only 60 cm.....
I have a TP-Link N150 card for my PC right now with matching external antenna that is 130 cm....it's great, i could probably go down as low as 100 cm but really can't be shorter than that....
I'm also open to alternative external antenna options that can accommodate 2 or 3 antennas.
Thanks!
Thanks!
