http://wl500g.info/entry.php?2942-Asus-PCE-AC66-Dual-Band-PCI-e-AdapterAsus PCE-AC66 Dual-Band PCI-E 802.11ac Wireless-AC1750 Adapter
ASUS PCE-AC66 Next Generation AC Dual-Band Wireless Adapter IEEE 802.11ac,
802.11b/g/n PCI Express Up to 1750Mbps (450/1300Mbps) Wireless Data Rates
PCE-AC66 802.11ac Dual-band Wireless-AC1750 PCI-E Adapter
http://www.asus.com/Networks/Wireless_Adapters/PCEAC66/
- 5th generation 802.11ac chipset gives you dual-band 2.4GHz/5GHz for up to super-fast 1.30Gbps
- Flexible extended antenna placement helps you pinpoint the best reception in your environment.
- Instant Wi-Fi upgrade for your desktop: no more messy Ethernet cables needed.
- High-power design clears up dead zones with 150% greater coverage
- Custom heatsink dissipates heat for more stable and reliable non-stop operation
Release Date: 12/31/2012 - http://www.newegg.com/Product/Product.aspx?Item=N82E16833320136
- IEEE 802.11ac, IEEE 802.11b/g/n
- Up to 1750Mbps (450/1300Mbps) Wireless Data Rates
- 2.4GHz/5GHz
Asus PCE-AC66 BCM4360 PCI Express 3 x 3 802.11ac 1.3Gbps (5GHz) + 450Mbps (2.4GHz)
Asus USB-AC53 BCM43526 USB port 2 x 2 802.11ac 867Mbps (5GHz) + 300Mbps (2.4GHz)
http://www.broadcom.com/press/release.php?id=s637241
- BCM4360 supports PCIe interface and implements 3-stream 802.11ac specifications, speeds up to 1.3 Gbps.
- BCM4352 supports PCIe interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
- BCM43526 supports USB interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
- BCM43516 supports USB and reaches speeds of up to 433 Mbps with its single stream 802.11ac implementation.
Full 802.11ac product lineup
In addition to the RT-AC66U router, ASUS has also released the PCE-AC66 and USB-AC53 clients, both capable of 802.11ac speeds.
The dual-band PCE-AC66 offers a PCI Express client card for desktops, with 3 x 3 high-powered transmission. It can sustain 1.3Gbps
in 5GHz and up to 450Mbps in the 2.4GHz band. For easy USB upgrades to 802.11ac, the USB-AC53 compact dongle plugs into any
USB port, with 2 x 2 802.11ac. In 5GHz, the attachment can maintain 867Mbps, while in 2.4GHz it works at 300Mbps, achieving a
total throughput of around 1.3Gbps. The PCE-AC66 and USB-AC53 are enabled by Broadcom’s 5G WiFi chips, and demonstrate ASUS
technology leadership in bringing an 802.11ac ecosystem to consumers.
http://www.asus.com/News/rZcy4jXiQPQ5F8YL/
ASUS PCE-AC66 Dual-Band PCI-E Adapter which is capable of 802.11ac speeds. This dual-band PCE-AC66 offers a PCI Express client
card for desktops, with 3 x 3 high-powered transmission. It can sustain 1.3Gbps in 5GHz and up to 450Mbps in the 2.4GHz band.
The PCE-AC66 are enabled by Broadcom’s 5G WiFi chips, and demonstrate ASUS technology leadership in bringing an 802.11ac ecosystem to consumers.
http://www.facebook.com/media/set/?set=a.10151284872864116.494386.284216439115&type=1
