I'm having a very difficult problem. My PCE-AC68 is installed and recognized properly in the device manager. Both my 2.4 and 5 network are visible to the PCE-AC68. When I try to connect it is impossible, like it will not recognize my password or something more fundamental with the PCE-AC68. It simply will not connect to either network. I reset the router. Turned it to an open network so no password was required. Installed both the older driver version, and the newest 2071 driver. Reinstalled the driver and uninstalled about 10 times. No success, still same problem. Never able to connect to the network. I also tried turning off the beam forming and other advanced features and with no success. I can easily connect to the network on the same computer using a USB wifi adapter. Is my PCE-AC68 defective or is this a software issue? Asus helpline had no ideas. About ready to return it.
Windows 8.1 64 bit. Linksys router.
