This PCI addon card itself works ok under windows 10, but the utility does not.
The utility allows to configure access point and various other settings such as what channel it broadcasts on.
My problem is that the default channel is 10 (WHYY??), which is kind of weird since the standard is 1, 6 or 11 at least in Europe.
I searched high and low, but I can't find any way to change the channel. It's not doable through driver settings in device manager and I can't find any commands via CMD either. Any tips?
What I learned today was that channel overlapping is much more detrimental to WiFi performance, than being on a crowded channel. So for my own sake, and not to disturb surrounding WiFi channels I would like to be able to change my channel for a good experience for all
Thanks in advance!
Thanks in advance!
