Release Asus ROG GT-AC2900 version 3.0.0.4.386.46092 (2022/03/02)
Darkje
ASUS GT-AC2900 Firmware version 3.0.0.4.386.46092
Security
- Fixed string format stacks vulnerability
- Fixed cross-site-scripting vulnerability
- Fixed informational vulnerability.
Thanks to Howard McGreehan.
-Fixed SQL injection vulnerability
-Fixed json file traversal vulnerability
-Fixed plc/port file traversal vulnerability
-Fixed stack overflow vulnerability
Thanks to HP of Cyber Kunlun Lab
-Fixed authenticated stored XSS vulnerability
Thanks to Luke Walker – SmartDCC
-Fixed LPD denial of service vulnerability
-Fixed cfgserver heap overflow vulnerability
-Fixed cfgserver denial of service vulnerability
Thanks to TianHe from BeFun Cyber SecurityLab.
-Fixed CVE-2021-34174, CVE-2022-23972, CVE-2022-23970, CVE-2022-23971, CVE-2022-23973
Added more ISP profile
Digi 1 - TM
Digi 2 - TIME
Digi 3 - Digi
Digi 4 - CTS
Digi 5 - ALLO
Digi 6 - SACOFA
Maxis - CTS
Maxis - SACOFA
Maxis - TNB/ALLO
Fixed AiMesh guest network issues.
Fixed DDNS issues where the WAN IP is IPv6
Fixed UI bugs in Administration --> feedback.
Fixed time zone error.
Improved the connection stability.
Fixed IPSecVPN issues.
Please unzip the firmware file first then check the MD5 code.
MD5:5d2e2cc332d455d9a6ca4d0bfc1274db
isn't this router an ac86u with LEDs !!!! I feel asus is trolling as at this stage :D :D
You've only been trolled of you give money for one. :p
Yes basically it is the same device. It is even possible to flip the units form model a to b.
86u will come I do think gt owners should be first they did eventually spend more money . Besides on gt loadbalancing is still non functional.
