ASUS ROG Rapture GT-BE98 possible with ASUS DSL-AX82U (modem only)?
Mappi75
Hello all, :)
After several tests with different modems, it turned out that the modem of the Asus router DSL-AX82U (BCM 63178) is the most stable.
(Currently, only VDSL250 fibre optic is being expanded.)
I would therefore like to use ONLY the DSL-AX82U modem (if possible).
I am aware that I could use the GT-BE98 as a client, but as it is much more powerful, I want it to be the main router.
(The DSL-AX82U should not set up a WLAN or anything else, it should only provide and use the internal modem.)
I have tried the settings from this video (DSL-AX82U=Bridge-Mode):
But I cannot establish an Internet connection from GT-BE98 via PPPoE on DSL-AX82U.
Connected via LAN CAT8 cable via LAN1 Port DSL-AX82U to GT-BE98 WAN 10 GB Port.
AND DSL-AX82U LAN 4 Port to GT-BE98 LAN 4 Port.
GT-BE98: 192.168.1.3
DSL-AX82U: 192.168.1.1
both: 255.255.255.0
both: latest firmware
Thank you very much!
