Asus Router App - iPhone.
losdelrock
Hi All, not sure what firmware this started happening at but probably 380.66 or thereabouts.
My Asus Router App (iPhone in my case) now no longer connects, on first run it sees the router, for a split second it connects, then says connecting then comes up "Connection failed".
Asus AC5300 running 380.68 currently.
I have tried on the various ports, (80,8088, 8443), also firmwares from 380.66 to 380.68 but no joy.
Any ideas?
Thanks,
Adrian.
My app often fails on first attempt to connect, press the refresh and it connect 99% of the time. As you say it seems to have been like this for the last 2-3 Merlin releases.
Thanks JDB, but it is worse than that. If I unlink my router, it tries to discover and find it, then fails.
If I hard reboot the router, then it discovers it but eventually says "Connection Failed"
Adrian.
