Asus router tm-ac1900 -> ac68u change the firmware, There are an infinite reboot.
koyoungyi
CFE has changed as I 1.0.2.0 ...
Only the secret code has not changed.
I just went into reset mode firmware change this and that 'm the same error .
LOOP!!!!!
Decompressing...done
[<c003d334>] (do_IPI+0x114/0x154) from [<c037c048>] (__irq_svc+0x48/0xe8)
Exception stack(0xcf843f98 to 0xcf843fe0)
3f80: 00000002 cf821200
3fa0: cf843fe0 00000000 cf842000 c03d90a8 c03c2b80 c03d9214 00000000 413fc090
3fc0: 0000001f 00000000 00000000 cf843fe0 c003ebe4 c003ebe8 60000013 ffffffff
[<c037c048>] (__irq_svc+0x48/0xe8) from [<c003ebe8>] (default_idle+0x24/0x28)
[<c003ebe8>] (default_idle+0x24/0x28) from [<c003ed88>] (cpu_idle+0x70/0xa4)
[<c003ed88>] (cpu_idle+0x70/0xa4) from [<00008084>] (0x8084)
[<c0008ca4>] (start_kernel+0x33c/0x398) from [<00008084>] (0x8084)
Rebooting in 3 seconds..
Digital core power voltage set to 0.9375V
Will you have any solutions ?
Discard it ?
