Asus routers and NVRAM (AC-RT3200)
Nigel Jones
Today my primary ISP failed... after a few hours on a tethered phone I spent a moment setting up dual WAN as my old ISP is still active for a couple of weeks. Worked a treat.
Having done this I noticed my nvram was getting low (I'm running merlin firmware). Currently at 62971 / 65536 bytes
Currently I have enabled
- AIprotection (all options, looks useful)
- Adaptive QOS including app analysis, web history
- traffic stats
- 2 OpenVPN servers (1 tap, 1 tun) - just about 2 ids on each
- dual WAN
I'm not using an NFS, SNB, other USB devices etc.
I was a little surprised that I don't see I'm really using the device much more than intended yet hitting this rather low limit.
Are there particular features above that are likely to eat more nvram?
Am I right in thinking that the first (cheapest) ASUS model that "fixes" this is the AC-88u? (and then the 5300)? But not any revisions of the AC-68u nor the weird AC-87u ?
Does the firmware do any automatic garbage collection? So having it pretty full isn't really an issue?
The RT-AC3200 is a specific case. Same problem as with the RT-N16, they added features to these two devices without also increasing nvram, which leads to running out of nvram rather easily, even with a fairly basic setup.
The RT-AC68U does not have such issue because it only has two wireless radios - most of that space is used by the AC3200's third radio.
Thanks, yes I can see that radio is definitely taking up quite a bit more config data.
Interesting the vpn config is quite significant too
nigel@RT-AC3200-AD90:/tmp/home/root# nvram show | grep '^vpn' | wc
size: 60947 bytes (4589 left)
381 381 8696
In particular there are variables present (I cleared them, they came back) that relate to all the clients/servers, even if, as in my case, I'm only using one vpn server and no clients. Any scope for removing anything there?
Default variables cannot really be removed, they will eventually just be re-created.
I did the test, and each OpenVPN client instance takes close to 1 KB of nvram.
So what would be the best way to lower the NVRAM use? Can traffic.db be moved to USB? Or something along those lines?
