niccofox
I currently have an AX11000 which is my main router on the 1st floor then an AiMesh node which is the AX82U on the 2nd floor. I also bought cheap routers around < $35 which are the RT-AC5300, TUF-AX3000, and AX55. I live in a 500sqm lot and the house is around 300sqm. What would be the best routers to keep? Definitely my AX11000 will stay. I don't know if I should still keep the AC5300 as it has a wide coverage but no wi-fi 6. Maybe its either I keep that then flip the other two used routers OR I keep the two used routers then sell the AC5300. What could I do with those?
