sunil.gulabani
Hi I need two routers for two different locations.
I need one router that can be the fastest for reading and writing between two PCS at the fastest possible speed. This router shall be connected to 20Mbps Internet connection.. I am currently using a 2.4Ghz usb 2.0 adapter on one of the computers which I plan to change to a dual band PCI Express wifi ac adapter/USB3.0 AC ADAPTER so that it can help with the data transfer. The other PC is connected directly to the router. This router shall also be hooked on a DVR Camera that streams video via dyndns. Also a WDTV media player will be connected wired or wireless... Please suggest from the list... As these are lately the most common routers available here.. atleast in the AC technology. As far as range is concerned one PC is in the same room connected to the router and the other is like a wall away... But I need superfast read/write speeds between the two pcs thats the main requirement. Unfortunately the second PC cannot be connected to the router using a wired connection and has to be wireless. Current Router in this location is WRT-160N and does an extremely crappy job of data transfer between the two PCS.. I have done lan speed test and got some pathetic results..To write 10 packets of data it took 8.98 seconds and to read 10.09 seconds for 10 packets of data..
The other router will be connected to multiple devices at a given time such as a desktop, a mac mini, iphone, android phones, LG Smart TV for streaming movies including 3D movies from the router connected USB 3.0 or on the PC..The PC has already been updated to PCI Express ASUS 1900 AC adapter. I need this router to flawlessly do data transfer reading, writing, streaming media on any device to and from.. without wanting to ever see "buffering".. This location needs the best internet speeds max of 30MBPS and the best MEDIA STREAMING EVER...The current router LINKSYS E4200 does a decent job but at times on my iphone or the tablet the media stops streaming at certain as what one may call dead spots... Also at times the link between the TV and PC is broken and I need to reconnect... The TV and PC are also on the two separate ends of the router and the furthest from the router.
If anyone can suggest any other model as well I am open to it bear in mind that option may not be easily available at decent prices..
Thanks and Regards
PRICING AT WHICH MODELS AVAILABLE HERE
AC87U - 230 USD
WRT1900AC - 235 USD
AC68U - 185 USD
Though price is final consideration..
Thanks and Regards
AC87U - 230 USD
WRT1900AC - 235 USD
AC68U - 185 USD
