New to the forum, and not particularly hot on network stuff, but was sent here from the Virgin Media Community by some contributors there. I hope this is the correct Forum for this post.
I have a Virgin Media Hub 3 in Modem mode, port 1 to Asus AC1200G+ Router, and I am on the VM 600 Mbps service.
Wi-fi works fine, around 150 - 200 Mbps, I appreciate there are lots to influence it, but I went to the Asus router years ago as Hub 3 router mode wi-fi was poor.
My indication that something is amiss is in a wired Ethernet connection to my iMac via the Asus router!
If I connect my Mac to the VM Hub 3 in Modem mode directly (only 1 ethernet cable to my Mac from the Hub), I get over 600Mbps on the wired connection, so I know the VM Hub is outputting the correct bandwidth/speed in Modem mode.
However with Hub 3 in modem and connected to my Asus Router, the wired connection from the router to the iMac drops to about 250Mbps.
I want to retain the router obviously, as the Wifi from that is better than the VM Hub in router mode, but I really expected to get the same 600 Mbps speed via the routers wired ethernet connections.
I'll be adding an unmanaged switch to one of the router ports soon as I have more wired devices (PC, TV, Home Alarm) I'd like on wired connections.
Any help appreciated.
- QoS is disabled.
- I've tried another port from the Hub to the Router.
- Router is updated with the latest Firmware.
Hub 3 and ASUS RT-AC1200G+ with 600Mbps speed package
Set up as Hub 3 in Modem mode, port 1 to Asus Router, and I just recently moved from M200 to M600 speed. Wi-fi works fine, around 150 - 200 Mbps, I appreciate there are lots to influence it, but I went to the Asus router years ago as Hub 3 router mode wi-fi was poor. My indication that...
community.virginmedia.com
