Asus RT-AC1900U
Paulo Ramos
I bought a new Asus router to replace the old one.
I want to install Merlin firmware, but I have some doubts if this model is supported.
The model is RT-AC1900U.
Can someone confirm and tell me which version to install?
The current version for you and most of us is 384.7_2 or 384.8 beta2. You can find both here listed as updates for the AC68U which is technically the same router. https://onedrive.live.com/?authkey=!AJLLKAY--4EBqDo&id=CCE5625ED3599CE0!1444&cid=CCE5625ED3599CE0
Thank you for the reply.
Why Asus rename the hardware?!?! Why don't they keep it simple?!??!
If you look up your model and go to that folder, inside is a redirect readme to the AC68U page.:rolleyes:
