The router disconnects the xbox one x and I have no idea why. Tv, laptop and smartphone is connected to the router and they function just fine. I ticked the box optimise for xbox and there's no difference. I even put the xbox ip in DMZ. Same problem.
The log shows the following:
Dec 26 17:17:23 acsd: eth6: NONACSD channel switching to channel spec: 0xe26a (108/80)
Dec 26 17:21:00 acsd: selected channel spec: 0xe36a (112/80)
Dec 26 17:21:00 acsd: Adjusted channel spec: 0xe36a (112/80)
Dec 26 17:21:23 acsd: selected channel spec: 0xe36a (112/80)
Dec 26 17:21:23 acsd: Adjusted channel spec: 0xe36a (112/80)
Dec 26 17:21:27 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth6: Disassoc , status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Dec 26 17:21:27 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth6: Auth
Dec 26 16:21:27 dnsmasq-dhcp[2527]: DHCPREQUEST(br0)
Dec 26 16:21:27 dnsmasq-dhcp[2527]: DHCPACK(br0)
Dec 26 17:21:28 acsd: eth6: NONACSD channel switching to channel spec: 0xe36a (112/80)
Also why does the time jump between accurate time and 1 hour ago?
Ideas anyone? I bought the router yesterday
Edit: distance between router and xbox is 2,5 meters /9 feet
