Asus RT-AC3100 Firmware. 384.32738
jim769
Version 3.0.0.4.384.327382018/08/2045.33 MBytes
ASUS RT-AC3100 Firmware version 3.0.0.4.384.32738
AiMesh new features
- Supported creating mesh system with new router, BlueCave.
- Added Roaming block list in Advanced Settings --> Wireless.
You can add devices into block list and this device will not be roamed between AiMesh nodes.
- Supported ethernet onboarding. User can use ethernet cable.
You can use ethernet cable to connect AiMesh router LAN port and AiMesh node WAN port first and run the adding node process to build the mesh system.
Security fixes.
- Fixed Reflected XSS vulnerability.
- Fixed CSRF vulnerability.
- Fixed command injection vulnerability.
- Fixed stack buffer overflow vulnerability.
Thanks for Rick Ramgattie contribution.
Fixed USB hard drive over 2TB compatibility issues.
Fixed Samba/FTP folder permission issues.
Added USB3.0/2.0 mode switch setting in Administration --> System --> USB Settings.
https://www.asus.com/us/Networking/RT-AC3100/HelpDesk_Download/
