WhizzWr
Hi AC51U owner, what kind of wireless throughput are you getting from this router?
I have 100Mbit/s WAN but when I tested the router with with Intel 7260N 2x2 (300 Mbps link speed) Laptop, the downlink throughput is capped at 82 Mbit/s, strangely uplink reaches 98 Mbit/s just fine. . Same goes with my wireless-AC Android phone (433 Mbps link speed), uplink is maxed, but it's getting 15-20 mbps lower than the actual WAN speed. Test is done in point blank range (ca 2 m laptop/phone <--> router)
Any pointer? CPU is on 40% or so during speed test, setting is left mostly as default. This is reproduceable with stock firmware and Padavan's build, both 5 Ghz and 2.4 Ghz given the same distance.
