After updating the firmware on my RT-AC5300 (to Version 3.0.0.4.386.43576), carrying out a factory restore, and setting up my Router (disabling Airtime fairness) I was unable to maintain a connection between my iPhone or iPad and my Sky Q Boxes (AirPlay), or AirPrint Printer. Also Amazon Alexa seemed to be buffering regularly.
I have not had these issues for the last few years, since i discovered the need to disable "Airtime Fairness". I re-enabled 'Airtime Fairness" on the 2.4GHz, 5GHz-1 & 5GHz-2 and rebooted, then disabled it and rebooted again, with no improvement. After each change to the Routers settings I was able to connect across the devices for approx. 10 minutes before it failed again.
Is there another setting somewhere that needs changing and I've missed?
I may try reverting to the previous Firmware, Version 3.0.0.4.386.43129, to see if this resolves the connectivity issues.
