BiggShooter
I just purchased the Asus RT-AC5300. I'm on the fence whether to return it or not (purchased from Amazon). I've had a few issues, and I'm hoping to get some input from as many users as possible.
Issue 1: A few (two) of the antenna "connectors" are loose. It's not the actual antenna itself, but the small connector the antenna connects to. I can actually "turn" the connector slightly from left to right / right to left. It seems the connector is loose from inside the Asus RT-AC5300. Has anyone had this issue? Is there simple fix? Should I send it back and request a new Asus RT-AC5300?
Issue 2: Smart Connect seems to work well however, a few devices have an issue connecting [with Smart Connect ENABLED]. I have the Nest Cam. When I reserve an IP address for the Nest Cam [and Smart Connect is ENABLED], it will NOT connect to any of the wifi radios. With no IP reservation assigned to the Nest Cam, it will connect to one of the 5GHz wifi radios. If I disable Smart Connect, the Nest Cam will connect with the reservation IP address I have assigned to the Nest Cam.
Issue 3: It seems w/ SmartConnect ENABLED or DISABLED, the balance between the two 5GHz radios is "lopsided". It seems that only one of the 5GHz radios (5GHz-1) allows just a few 5GHz devices, while the 5GHz-2 radio has the rest (8+ devices). Has anyone figured out how to get a better "balance" so that both 5GHz radios are balanced w/ connected devices?
I'm very impressed overall with the rest of the functionality of the Asus RT-AC5300. I'm just hoping someone might be able to shed some light on the following issues I've experienced. Thanks for taking time to provide a response.
