I got Smart Connect (Tri Band) working on all my devices by resetting the SSID = changed SSID to another value and then changed it back on the screen where you can enable or disable Smart Connect.
I also made sure 2.4 GHz was selected in the dropdown before selecting the 'button' to enable Smart Connect (one would think this should not matter).
Now that I have it working for everything, Smart Connect is selecting the 5 GHz band for only 3 of 11 wifi devices that are actively connected...
2 Smart phones and 1 Roku 3 are on 5 Ghz.
I suspect it will be one more on 5 GHz once I connect my USB adapter for one of my laptops.
(My Tivos are all connected via MoCA so they don't use wifi, otherwise it would be more).
Anyway, is it really that ineffective at detecting which clients would be better served on the 5 GHz network or has it truly determined that my 2.4 GHz band is working so well (few neighboring networks near by and excellent speed) that it feels it doesn't need to put the Roku and Smart TV devices on my 5 GHz band?
Right now it has 1 of 5 Rokus on 5 GHz and 4 on 2.4 GHz
I will see how Smart Connect works for a while and then perhaps disable it and go back to manual assignment.
PS: It appears clients (like Roku 3 streamers) will not auto switch between 2.4 and 5 GHz depending on parameters such as wifi signal strength.
