ASUS RT-AC56U Firmware version 3.0.0.4.374.4422
speedingcheetah
Security related issues:
1. Fixed lighthttpd vulnerability.
2. Fixed cross-site scripting vulnerability (CWE-79).
3. Fixed the authentication bypass (CWW-592).
4. Added notification to help avoid security risks.
5. Fixed network place(samba) and FTP vulnerability.
Improvement:
1. Redesigned the parental control time setting UI.
2. Updated multi language strings.
3. Adjusted FW checking algorithm.
4. Adjusted Time zone detecting algorithm.
5. Improved web UI performance.
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC56U/FW_RT_AC56U_30043744422.zip
Hello,
After upgrading to this version, after I reset my router, when I configure it back after I input my username and password for my pppoe connection, it goes into asus homepage instead to continue to next screen to set up password for wi-fi.
Hello,
A reset is not necessary...simple reboot is all that is needed after upgrading.
Installed the firmware. The only unusual thing happened is the manual reboot post install only option & it asked me to change network place (samba) permission to "Share with account" which already was set this way before. Anyway, I set it to "Share without account" then changed it back to "Share with account" & the yellow icon was gone.
It seems they added a notification system to advise you of insecure settings.....very good idea Asus.
I have got the yellow arrow icon too....but mine said my 2.4ghz wifi was insure and I should adjust settings....however, I ignore it, as I have the 2.4 band disabled...the bottom of the balloon notification..it has a link that says Undefined...so it seems Asus has a tad more work to do in this new feature.
