ASUS RT-AC56U - Merlin 374.43_2 - Dual Wan does not respect Port Forwarding
Bouba
I would like to know if what I would like to have with my router is possible or not.
I have a router Asus RT-AC56U and I use the single WAN and I have open the port 7001 in the Port Forwarding.
When I use my Iphone with 3G I see that this configuration works. I can connect the PC that is behind the port 7001 (that I forwrad with Port Forwarding).
Now I configure and start the Dual Wan functionnality with Load Balancing (2 connections in parralel).
I see that the 2 ports WAN have an IP Address.
With my iphone in 3G I try to connect to the port 7001 with the IP address of WAN 1 (Primary WAN) --> it works.
With my iphone in 3G I try to connect to the port 7001 with the IP address of WAN 2 (Secondary WAN) --> it does not work --> I have no answer!!!!
Do you know if the Port Forwarding works with the Dual Wan in Load Balacing mode?
PS : I have also seen that if the Primary WAN has not an IP address in first (--> the Secondary WAN has received the IP address in first) then the port forwarding works only with the Secondary WAN IP address.
KR,
Steve,
