abescalamis
Hello, I'm having an issue when setting port forwarding, I have a foscam Ip camera that uses port 88. When I set to forward port 88 on both (UPD + TCP) and it doesn't work, I've change the camera port to 8090 with the same results. I tested using the link below but the router won't open the port.
http://www.yougetsignal.com/tools/open-ports/
Does anyone have a suggestion? I already reset the router to factory default via GUI and via WPS then I set the router again and still doesn't open the ports.
