I have an assus router running merlin that always shows SYN packets coming in the logs.
Is this normal or someone is trying to hack me?
This was happening for a long time, even when the router was running with default firmware.
May 6 14:07:03 kernel: DROP IN=ppp0 OUT= MAC= SRC=202.188.205.115 DST=82.77.76.94 LEN=48 TOS=0x00 PREC=0x00 TTL=135 ID=5061 DF PROTO=TCP SPT=50997 DPT=44614 SEQ=3240552478 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (020405AC01010402)
May 6 14:07:03 kernel: DROP IN=ppp0 OUT= MAC= SRC=85.222.16.246 DST=82.77.76.94 LEN=48 TOS=0x00 PREC=0x00 TTL=114 ID=31465 DF PROTO=TCP SPT=5082 DPT=443 SEQ=45667272 ACK=0 WINDOW=8192 RES=0x00 SYN URGP=0 OPT (0204058C01010402)
May 6 14:10:04 kernel: DROP IN=ppp0 OUT= MAC= SRC=123.207.89.179 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=238 ID=11407 PROTO=TCP SPT=57774 DPT=1433 SEQ=343106888 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:10:18 kernel: DROP IN=ppp0 OUT= MAC= SRC=151.250.71.206 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=53084 PROTO=TCP SPT=43586 DPT=23 SEQ=1380797534 ACK=0 WINDOW=18641 RES=0x00 SYN URGP=0
May 6 14:10:33 kernel: DROP IN=ppp0 OUT= MAC= SRC=94.177.186.109 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=50519 DPT=22 SEQ=2100761562 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
May 6 14:10:47 kernel: DROP IN=ppp0 OUT= MAC= SRC=163.172.210.67 DST=82.77.76.94 LEN=431 TOS=0x00 PREC=0x00 TTL=51 ID=27377 DF PROTO=UDP SPT=5084 DPT=5060 LEN=411
May 6 14:10:49 kernel: DROP IN=ppp0 OUT= MAC= SRC=169.54.233.121 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=21888 DPT=502 SEQ=117854433 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
May 6 14:12:12 kernel: DROP IN=ppp0 OUT= MAC= SRC=45.55.12.151 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=49161 DPT=115 SEQ=2593799253 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
May 6 14:12:28 kernel: DROP IN=ppp0 OUT= MAC= SRC=27.254.96.49 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=41443 PROTO=TCP SPT=40292 DPT=23 SEQ=1820978602 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:12:57 kernel: DROP IN=ppp0 OUT= MAC= SRC=89.248.168.204 DST=82.77.76.94 LEN=247 TOS=0x00 PREC=0x00 TTL=251 ID=54321 PROTO=UDP SPT=47704 DPT=53413 LEN=227
May 6 14:14:08 kernel: DROP IN=ppp0 OUT= MAC= SRC=212.129.1.60 DST=82.77.76.94 LEN=437 TOS=0x00 PREC=0x00 TTL=54 ID=58228 DF PROTO=UDP SPT=7694 DPT=5060 LEN=417
May 6 14:14:34 kernel: DROP IN=ppp0 OUT= MAC= SRC=188.16.45.20 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=29352 PROTO=TCP SPT=51064 DPT=23 SEQ=1380797534 ACK=0 WINDOW=61768 RES=0x00 SYN URGP=0
May 6 14:14:55 kernel: DROP IN=ppp0 OUT= MAC= SRC=37.148.208.15 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=32709 PROTO=TCP SPT=54122 DPT=1433 SEQ=2602382850 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:15:37 kernel: DROP IN=ppp0 OUT= MAC= SRC=210.37.2.181 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=234 ID=55495 PROTO=TCP SPT=53058 DPT=23 SEQ=2202834062 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:17:06 kernel: DROP IN=ppp0 OUT= MAC= SRC=37.61.220.243 DST=82.77.76.94 LEN=433 TOS=0x00 PREC=0x00 TTL=58 ID=42548 DF PROTO=UDP SPT=25952 DPT=5060 LEN=413
May 6 14:17:24 kernel: DROP IN=ppp0 OUT= MAC= SRC=203.195.209.108 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=2230 PROTO=TCP SPT=49295 DPT=23 SEQ=2119582975 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:18:38 kernel: DROP IN=ppp0 OUT= MAC= SRC=93.174.93.136 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=251 ID=31347 PROTO=TCP SPT=52895 DPT=8893 SEQ=406852752 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:18:57 kernel: DROP IN=ppp0 OUT= MAC= SRC=163.172.135.224 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=20803 PROTO=TCP SPT=49166 DPT=3128 SEQ=3856470309 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:19:17 kernel: DROP IN=ppp0 OUT= MAC= SRC=112.72.15.14 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=52 ID=6052 PROTO=TCP SPT=43063 DPT=23 SEQ=1380797534 ACK=0 WINDOW=45871 RES=0x00 SYN URGP=0
May 6 14:19:36 kernel: DROP IN=ppp0 OUT= MAC= SRC=212.47.241.246 DST=82.77.76.94 LEN=432 TOS=0x00 PREC=0x00 TTL=50 ID=4595 DF PROTO=UDP SPT=5596 DPT=5071 LEN=412
May 6 14:19:40 kernel: DROP IN=ppp0 OUT= MAC= SRC=122.114.13.88 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=113 ID=256 PROTO=TCP SPT=25933 DPT=80 SEQ=1682767872 ACK=0 WINDOW=16384 RES=0x00 SYN URGP=0
May 6 14:20:05 kernel: DROP IN=ppp0 OUT= MAC= SRC=123.207.4.86 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=22950 PROTO=TCP SPT=53482 DPT=1433 SEQ=4076605537 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:20:22 kernel: DROP IN=ppp0 OUT= MAC= SRC=198.20.69.74 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=115 ID=7752 PROTO=TCP SPT=24366 DPT=2404 SEQ=2556011902 ACK=0 WINDOW=43279 RES=0x00 SYN URGP=0
May 6 14:21:10 kernel: DROP IN=ppp0 OUT= MAC= SRC=123.207.145.140 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=9335 PROTO=TCP SPT=59859 DPT=1433 SEQ=1467510192 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:23:31 kernel: DROP IN=ppp0 OUT= MAC= SRC=89.248.167.131 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=124 ID=44927 PROTO=TCP SPT=4006 DPT=6000 SEQ=1859890942 ACK=0 WINDOW=17539 RES=0x00 SYN URGP=0
May 6 14:24:59 kernel: DROP IN=ppp0 OUT= MAC= SRC=212.47.241.246 DST=82.77.76.94 LEN=432 TOS=0x00 PREC=0x00 TTL=50 ID=24811 DF PROTO=UDP SPT=5262 DPT=5070 LEN=412
May 6 14:25:58 kernel: DROP IN=ppp0 OUT= MAC= SRC=185.38.150.23 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=54321 PROTO=TCP SPT=46780 DPT=6379 SEQ=714108720 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
May 6 14:26:16 kernel: DROP IN=ppp0 OUT= MAC= SRC=51.15.161.147 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=35410 PROTO=TCP SPT=46956 DPT=5060 SEQ=1123407304 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:26:20 kernel: DROP IN=ppp0 OUT= MAC= SRC=163.172.109.187 DST=82.77.76.94 LEN=48 TOS=0x00 PREC=0x00 TTL=118 ID=25288 PROTO=TCP SPT=28529 DPT=22 SEQ=21318515 ACK=281794783 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B401010402)
May 6 14:27:17 kernel: DROP IN=ppp0 OUT= MAC= SRC=59.45.175.11 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=61800 PROTO=TCP SPT=9090 DPT=22 SEQ=30000 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0
May 6 14:27:44 kernel: DROP IN=ppp0 OUT= MAC= SRC=189.47.198.170 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=48 ID=56031 PROTO=TCP SPT=22905 DPT=23 SEQ=1380797534 ACK=0 WINDOW=64758 RES=0x00 SYN URGP=0
May 6 14:30:19 kernel: DROP IN=ppp0 OUT= MAC= SRC=212.47.241.246 DST=82.77.76.94 LEN=432 TOS=0x00 PREC=0x00 TTL=50 ID=44964 DF PROTO=UDP SPT=5474 DPT=5072 LEN=412
May 6 14:30:24 kernel: DROP IN=ppp0 OUT= MAC= SRC=123.207.6.141 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=239 ID=37072 PROTO=TCP SPT=45754 DPT=1433 SEQ=2260326679 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
May 6 14:31:08 kernel: DROP IN=ppp0 OUT= MAC= SRC=182.186.156.237 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=236 ID=20991 PROTO=TCP SPT=7716 DPT=23 SEQ=2451 ACK=0 WINDOW=14600 RES=0x00 SYN URGP=0
May 6 14:32:21 kernel: DROP IN=ppp0 OUT= MAC= SRC=185.129.148.234 DST=82.77.76.94 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=20126 PROTO=TCP SPT=43626 DPT=3389 SEQ=1836847101 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
