Hello friends,
I've been looking around the forum and found pretty similar problems to my problem, but unfortunately no answer has really solved it.
Like this threads:
http://forums.smallnetbuilder.com/showthread.php?t=12825
http://forums.smallnetbuilder.com/showthread.php?t=14476
So heres the deal, I moved into a apartment with 2 roommates because of school. The family that I rent from lives on the floors above. (I'ts a 3 story house). So basically there is around 7-8ish people who use the same connection. When I first got here the inet situation was a mess. They had 2 routers going at once with 2 different DHCP-servers. And the connection was total shirt. Like, it would work for 10sec before you got kicked out.
I took the job to fix the whole ordeal, so I took the zyxel p2812 router modem (wich comes from the inet provider) and put it in bridge mode so it only serves as a bridge, and then I bought a Asus RT-AC66U to use as a router. I set it up standard and have both the 2.4GHz and the 5GHz set to the same SSID. The channel controller and everything else is set to automatic or recommended. All the cat cabels are either CAT5e or CAT6.
It all worked fine for about a month or 2.
Then I and others started to loose connection quite often. Its VERY sporadically when and how often it happens. Sometime it happens every minute/30 seconds, sometimes(if I pray to the internet gods) I have the connection a full day.
Something I noticed is that it often happens when one of my roommates comes home and gets on his computer. I've asked him about it and if his doing something to the inet and he denies that.(Im not accusing him or anything, its just an observation).
The router is running Firmware Version:3.0.0.4.274.
I've tried the tips and tricks thats in the guide linked earlier, but no results.
Heres a little snippet from the system log where the connection dropped all the time, the log is like this no matter what. So I dont know if this helps but I might as well give it a shot since im lost.
Jan 10 15:53:40 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.181 c0:18:85:f8:b1:91 Nesteby1-PC
Jan 10 15:54:24 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.21 a4:17:31:0b:6d:e4
Jan 10 15:54:24 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.21 a4:17:31:0b:6d:e4 Balder-PC
Jan 10 15:55:38 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.101 d0:51:62:38:00:a4
Jan 10 15:55:38 dnsmasq-dhcp[552]: DHCPNAK(br0) 192.168.1.101 d0:51:62:38:00:a4 wrong address
Jan 10 15:55:40 dnsmasq-dhcp[552]: DHCPDISCOVER(br0) d0:51:62:38:00:a4
Jan 10 15:55:40 dnsmasq-dhcp[552]: DHCPOFFER(br0) 192.168.1.26 d0:51:62:38:00:a4
Jan 10 15:55:40 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.26 d0:51:62:38:00:a4
Jan 10 15:55:40 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.26 d0:51:62:38:00:a4 android-f285480ad0ee9d03
Jan 10 15:56:17 miniupnpd[600]: HTTP Connection from 192.168.1.21 closed unexpectedly
Jan 10 15:56:30 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.103 bc:85:56:a9:cd:cf
Jan 10 15:56:30 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.103 bc:85:56:a9:cd:cf Froseth
Jan 10 15:56:34 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.103 bc:85:56:a9:cd:cf
Jan 10 15:56:34 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.103 bc:85:56:a9:cd:cf Froseth
Jan 10 15:56:39 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.103 bc:85:56:a9:cd:cf
Jan 10 15:56:39 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.103 bc:85:56:a9:cd:cf Froseth
Jan 10 15:56:48 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.103 bc:85:56:a9:cd:cf
Jan 10 15:56:48 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.103 bc:85:56:a9:cd:cf Froseth
Jan 10 15:58:47 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:58:47 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:00 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:59:00 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:03 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:59:03 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:13 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:59:13 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:22 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:59:22 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:26 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.242 00:c0:ca:75:23:17
Jan 10 15:59:26 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.242 00:c0:ca:75:23:17 Balder-PC
Jan 10 15:59:55 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.21 a4:17:31:0b:6d:e4
Jan 10 15:59:55 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.21 a4:17:31:0b:6d:e4 Balder-PC
Jan 10 16:01:26 dnsmasq-dhcp[552]: DHCPDISCOVER(br0) 00:25:ae:08:d6:6f
Jan 10 16:01:26 dnsmasq-dhcp[552]: DHCPOFFER(br0) 192.168.1.233 00:25:ae:08:d6:6f
Jan 10 16:01:26 dnsmasq-dhcp[552]: DHCPREQUEST(br0) 192.168.1.233 00:25:ae:08:d6:6f
Jan 10 16:01:26 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.233 00:25:ae:08:d6:6f
Jan 10 16:03:48 dnsmasq-dhcp[552]: DHCPINFORM(br0) 192.168.1.181 c0:18:85:f8:b1:91
Jan 10 16:03:48 dnsmasq-dhcp[552]: DHCPACK(br0) 192.168.1.181 c0:18:85:f8:b1:91 Nesteby1-PC
Jan 10 16:07:52 dnsmasq-dhcp[552]: DHCPDISCOVER(br0) 00:c0:ca:75:23:17
Jan 10 16:07:52 dnsmasq-dhcp[552]: DHCPOFFER(br0) 192.168.1.242 00:c0:ca:75:23:17
So any help would be greatly appreciated.
Oh, and the connection is a DSL connection if that matters.
Like this threads:
