ASUS RT-AC66U - Dual WAN with dedicated SSID's
Billd24
Background:
I have been searching the net for a few weeks to help address this issue, but have not found any direct solutions. I have 2 ISP's coming to the house - I work from home, and must have the redundancy. I tried Shibby's Tomato, but had stability issues - took a while to recover the AC66U from a bricked flash, so I'd like to stay with Merlin's build if possible, I am currently running 380.57.
The Problem:
Due to stability issues with both ISP's, I need the ability to easily switch devices to a specific a ISP. I am currently configured with the Load Balanced dual wan. Using Failover, is not desirable as I can't use the idle bandwidth I am paying for. The Dual Wan routing rules requires me to change the config by device when issues occur - serious PIA ...
The Desired Solution:
I'd like to create 2 Guest SSIDs, that are dedicated to each ISP. i.e. I want to create SSID "A", that only routes to ISP A, and SSID "B" that only routes to ISP B. This way I can select the working ISP from the device(s) I am working on.
To add a degree of difficulty, I also have a RT-N66U as an AP the basement that I'd like to have the same functionality.
Any thought on how to do this?
Thanks ...
