Asus RT-AC66U Rebooting Every 4 Hours
Scypher
Hi. I have the RT-AC66U, running Asuswrt-Merlin 380.68_4.
Its connected to a Cisco DPC3008 Cable Modem. Comcast. 250/25 connection.
Problem:
Router reboots/crashes once every 4 hours, 1-3 minutes after the hour, like clockwork. Graph, starting from when I started syslogging to remote server:
Background:
This started yesterday, after updating the router from its stock firmware (I don't remember what it was, but it was at least a couple years old.) to asuswrt-merlin 380. Nothing else changed. The only settings I've changed from stock merlin are:
Pre-noticing the problem:
enable ssh
iptables rule for port mirroring
post noticing the problem (no change):
disabled port mirroring
syslog log everything
syslog send to remote syslog server
DHCP query frequency from aggressive to normal
Logs:
Dec 4 08:01:07 192.168.1.1 Dec 4 16:00:39 kernel: DPT=161 LEN=68
Dec 4 08:01:10 192.168.1.1 Dec 4 16:01:07 kernel: 7 ID=14924 PROTO=UDP <1>SPT=63923 DPT=8888 LEN=9
Dec 4 08:02:04 192.168.1.1 Dec 4 16:02:04 dnsmasq-dhcp[296]: DHCPACK(br0) 192.168.1.139 34:f6:4b:75:cd:17 DESKTOP-ET6O021
Dec 4 08:02:04 192.168.1.1 Dec 4 16:02:04 dnsmasq-dhcp[296]: DHCPREQUEST(br0) 192.168.1.139 34:f6:4b:75:cd:17
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 1(vlan1) entering forwarding state
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: topology change detected, propagating
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 2(eth1) entering forwarding state
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 3(eth2) entering forwarding state
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 4(wl0.1) entering forwarding state
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: vlan1: add 33:33:00:00:00:02 mcast address to master interface
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 1(vlan1) entering learning state
Dec 4 08:02:59 192.168.1.1 Aug 1 00:00:15 kernel: br0: port 2(eth1) entering learning state
Dec 4 08:03:00 192.168.1.1 Aug 1 00:00:16 dropbear[280]: Running in background
Dec 4 08:03:00 192.168.1.1 Aug 1 00:00:15 WAN_Connection: ISP's DHCP did not function properly.
Dec 4 08:03:00 192.168.1.1 Aug 1 00:00:15 stop_nat_rules: apply the redirect_rules!
[ ... rest of reboot]
Metrics:
CPU - ~20%
RAM - ~23%
Temp - 57/63
Notes:
The date weirdness in the logs happens every time it reboots, and fixes itself later in the process. I don't know if that's normal. EDIT: I've come to assume this is the exact moment it crashes.
I don't actually know if the cable I'm using is cat 5 or cat5e. It doesn't say. It came in my comcast self-start kit a few months ago. That said, it hasnt caused any problems up till the upgrade. Further, I'm not seeing any Ethernet Link is Up/Down logs.
I've read a bunch of posts here and elsewhere about similar issues, but none of them solved it for me or fit my situation.
Help?
More info:
I no longer suspect DHCP from ISP, as my lease appears to be just shy of 4d.
I briefly thought maybe my LAN dhcp stuff was causing it, so I set my network lease time to 10m to troubleshoot. Everything is renewing without any issues.
NAT acceleration is and has always been off.
Update:
I did a factory reset, after which it went overnight without crashing. The only settings being changed at this point being wifi configured and remote syslog server.
Then yesterday, I changed the hostname, set it to use my internal dns server, and turned on firewall logs. It crashed on the next divisible by 4 hour (midnight).
I set dns back to auto and went to bed. It crashed at 4am, which I saw when I got up at 7am.
I then turned firewall logs off, leaving dns on auto. 8am rolled around, no crash.
So right now it appears to be firewall logs causing. I plan to dig in more because I really want my firewall logs, but first will confirm that is the issue. I've set dns back to my internal server and will see if it crashes at noon. I expect it will not, at which point I will turn logs back and see if it crashes at 4pm, which would confirm it.
With the metrics posted, is this at idle or just before the 4hr crash? I'm wondering if there is a log rotation or some other scheduled job that is running the router out of memory every 4 hours on start of the job.
Its pretty much constant from idle till the crashes. I haven't noticed any load spikes immediately prior to crash, but I'm also not collecting those metrics.
