asus rt-ac66u rebooting randomly
jazztrump9
Hello,
I installed merlin's most recent version about 3 weeks ago. It ran for 13 days with no issues, then randomly rebooted. I thought nothing of it, until the reboots started happening daily, then one morning it rebooted 4 times in a row. I reset to factory defaults and flashed the firmware to the newest beta hoping that would fix it and it didn't.
I have been going over the logs trying to figure out why it might be rebooting. The only thing I can think of is that its related to miniupnpd.
My log had several of these
Jul 13 22:50:05 miniupnpd[477]: upnp_event_recv: recv(): Connection reset by peer
Jul 13 22:54:33 miniupnpd[477]: upnp_event_recv: recv(): Connection reset by peer
Jul 13 22:57:47 miniupnpd[477]: upnp_event_recv: recv(): Connection reset by peer
and it rebooted literally right after that was logged.
I have stopped upnpd service to see if that helps. I can manually forward whatever ports i might need for the time being, but I cant seem to figure out these random reboots.
Check temperatures of your router, also make sure you have reset/restore factory defaults and after configure it from scratch (do not import other FW old config file), that messages are not the reason to reboots happening.
having same issue on build 380.57. Disabling Hardware Acceleration did not help. Any other ideas?
Hi!
How did you solved this problem? Clients DHCP tries to renew the address.
Oct  9 13:31:48 miniupnpd[14644]: upnp_event_recv: recv(): Connection reset by peer
Oct  9 13:32:32 dnsmasq-dhcp[2770]: DHCPREQUEST(br0) 192.168.1.14 00:90:f5:49:de:bd
Oct  9 13:32:32 dnsmasq-dhcp[2770]: DHCPACK(br0) 192.168.1.14 00:90:f5:49:de:bd
Oct  9 13:32:35 miniupnpd[14644]: upnp_event_recv: recv(): Connection reset by peer
Oct  9 13:47:59 miniupnpd[14644]: remove port mapping 29136 TCP because it has expired
Oct  9 13:47:59 miniupnpd[14644]: remove port mapping 29136 UDP because it has expired
