ASUS RT-AC68, rmerlin, and TorGuard
DaemonOfChaos
I have an ASUS RT-AC68 running rmerlin's firmware. I also have a TorGuard VPN account and have created a connection to TorGuard using the OpenVPN client.
Is it possible to send traffic to particular sites / IPs (e.g. Netflix, Hulu, my banks, and a few others) not through the VPN but through the "regular" or direct internet connection? Nothing in the admin interface is catching my eye for configuring that.
Not sure (some smart cookie around here will know) but this is the method I intend trying when I have time:
http://www.snbforums.com/threads/ho...nd-ssid-for-regular-isp-using-merlinwrt.9839/
EDIT
This looks like what you're after:
http://www.snbforums.com/threads/openvpn-policy-routing-guide.24384/
The first link appears to only work for wireless connections while I have some wired connections that also need to be handled.
The 2nd link looks spot on and I will give it a try. Thank you for the assist!
Here is an example:
#!/bin/sh
/usr/bin/logger -t START_$(basename $0) "started [$@]"
touch /tmp/000vpn_route_up.ran
logger -t "($(basename $0))" $$ "Starting custom vpn_route_up.sh"
echo "($(basename $0))" $$ "Starting vpn_route_up.sh"
ip route flush table 10
ip rule del table 10
ip rule del fwmark 10 table 10
ip route flush table 12
ip rule del table 12
ip rule del fwmark 12 table 12
ip route flush cache
iptables -t mangle -F PREROUTING
echo "($(basename $0))" $$ "RTNETLINK errors are from deleting tables that don't exist yet and can be ignored."
# NOTE: Here I assume the OpenVPN tunnel is named "tun11".
tun_if="tun11"
tun_ip=$(ifconfig $tun_if | grep 'inet addr:'| cut -d: -f2 | awk '{ print $1}')
logger -t "($(basename $0))" $$ "CMD: ip route add default via $tun_ip dev $tun_if table 10"
logger -t "($(basename $0))" $$ "CMD: ip route add default via $(nvram get wan_gateway) dev eth0 table 12"
ip rule add fwmark 10 table 10
ip route add default via $(nvram get wan0_gateway) dev eth0 table 12
ip rule add fwmark 12 table 12
echo 0 > /proc/sys/net/ipv4/conf/$tun_if/rp_filter
# Define the routing policies for the traffic. The rules will be applied in the order that they
# are listed. In the end, packets with MARK set to "10" will pass through the VPN. If MARK is set
# to "12" it will bypass the VPN.
# By default all traffic goes via the VPN
iptables -t mangle -A PREROUTING -i br0 -j MARK --set-mark 10
#examples
logger -t  $(basename $0) "Websites that need to go via ISP (Vpn bypass)"
# iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range website-ip-address-here -j MARK --set-mark 12
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 91.189.94.12 -j MARK --set-mark 12 # http://ubuntuforums.org/
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 155.136.80.216 -j MARK --set-mark 12 # http://www.natwestinternational.com
/usr/bin/logger -t STOP_$(basename $0) "return code $?"
exit
create a script and name it vpn_route_up.sh and save it to /jffs/scripts/.
Set permission to 755
add the following to the vpn client Custom Configuration box and press apply.
script-security 2
route-up /jffs/scripts/vpn_route_up.sh
to add particular sites / IPs (e.g. Netflix, Hulu, my banks, and a few others) you need to find out their Ip addresses in order to add them to the script.
see my example at the end of the scrip.
