I can't get much from Asus so I'd really appreciate any input this forum has on the below questions for my Asus RT-AC68P router setup. I've run an old Linksys router for the past decade so I'm not that up on Asus setups.
(1) The Router had it's own Firewall enabled by default but when I look at all the tabs in that window it really isn't config'd to filter anything (DoS is OFF, and no URL filters etc). And unless I figure out what I should filter (if anything) I'm wondering if I should just turn the Router firewall off. (I have a software firewall running on all my laptops).
(2)Under WAN settings it has UPnP enabled, does that really need to be enabled (?) as I've read it can be a security risk.
(3)In Administration it has Auto Logout set at 30 mins. I'm wondering if this means 30 mins of inactivity or just plain 30 mins (?) like maybe if I were doing something like a firmware flash I should disable the Auto Log out (?)
(4) In the traffic manager the first tab is Enable Smart QoS but it says to get bandwidths from ISP. It was set to OFF, do I need this ON ? Do I have to call my ISP for bandwidth data or is there a way online to get it?
