would benefit from installing the latest Merlin update?
Thank you for the reply. If I install Merlin on my new Asus AC68U, will it void the warranty?Depends what you are looking for. If you are looking for improved wireless performance, then the answer is no, it will be identical. If you are looking for doing more customization of your configuration, or using any of the highlighted changes, then yes.
.... If I install Merlin on my new Asus AC68U, will it void the warranty?
Welcome To SNBForums
