Asus RT AC68U DDNS problem
adicrst
Hi all,
I have a problem accessing my router via internet.
I use an O2 internet USB stick in Germany. I do not have other internet connection. The router created a Secondary WAN. Internet works fine
It register correctly in DDNS however with an internal IP
My router's internal IP is set to 10.2.0.1 and the IP it uses from the USB stick is 192.168.1.XX. In DDNS the registered IP is 192.168.1.100 instead of my external IP like 86.x.x.x. WHY ?
Is this a firmware bug or could it be because of the O2 provider ?
PS: i use latest stock firmware version
Try using another DDNS provider, like noip.
Simple check.
If it works with another provider you found the culprit.
