Raxxel
Hi people,
Is it possible that there is a problem with the reboot scheduler and the wlan time planer?
I want to use the reboot scheduler to boot the router once a day (07.30h) to have a clean system.
Also i want to reduce wlan usage with a time range from 07.00h until 23.00h.
But it seems to me that this combination does not function properly (i.e. first wlan ON, after that router-boot).
The Problem: Wlan is not available on the scheduled time (07.00h). Even if I change the wlan setting to 08.00h (i.e. first router-boot then wlan ON), wlan will not be available.
Could you please tell me whether I do something wrong?
How else can this be solved?
Many thanks in advance for your help.
Kind regards
Raxxel
Asus RT-AC68U
Merlin Firmware 380.64_2
Kind regards
Raxxel
Asus RT-AC68U
