Carl klang
Hi. I'm going to try to explain the problem I have with my IP TV. I've connected my Router directly to the ip tv and it has worked fine for a long time. But now since October a been experiencing both frames and sound freezes for a few seconds at a time and suddenly everything is back to normal for a while and then 1-5 minutes later it happens again? I can't figure out why.. I have tried update to the latest firmware and nothing changed. When I unplug the router and plug in the IP TV directly to the wall-socket it works fine. no LAG.
Right now im using Firmware Version:3.0.0.4.378_9313
The settings im useing at the monent is
Select ISP Profile ---------------------------------------------->None
Choose IPTV STB Port ---------------------->Lan3 & Lan4 (I move the box to the bed room sometimes)
Special Applications
Use DHCP routes ----------------------------------------------> Microsoft
Enable multicast routing (IGMP Proxy) --------------------->Enable
Enable efficient multicast forwarding (IGMP Snooping)--->Enable
UDP Proxy (Udpxy)--------------------------------------------->0
I hope someone knows what the problem could be. Thanks!
