I did see this as an update earlier today. However when I have returned to update the router this is no longer offered as an update. Its not on the UK site either....Just noticed that ASUS released new firmware for the RT-AC68U, 3.0.0.4.385_20632. It's currently available via update through the admin web UI. Haven't read the release notes yet.
It'll be interesting to see if other devices like my RT-AC3100 get an update from 20630 as well. Both AC68's went from 20630 to 20632 via the GUI wo/issue.With a small version increment, it's possibly a small bug fix. I've sent 2 feedback logs on the AC68U with performance and stability bugs.
Good point but I dont understand why the log says "Deauth...reason due to inactivity (4)" at the time of the streaming stopping. 5 ghz no longer does this since this firmware update so have they fixed 5 ghz and need to now look at 2.4?The 2.4 GHz band is often saturated with radio interference. This might not necessarily be caused by the router but could be an external source of interference on that frequency band.
I already have Wifi analyser and the 2.4 band has around another 3 routers. The AC68U is set to fixed channels, 11 and 44. Trouble is when I change the 2.4 channel there is a BT router that seems to follow it and maybe that is interfering as it is the strongest signal. I will try 5 ghz for a while and see if it is any better.5Ghz doesn't travel as far or through walls as well as 2.4Ghz, but 2.4Ghz as RMerlin stated is going to be affected more so by interference than the 5Ghz band.
I recommend downloading a Wifi analyzer on your smartphone, such as WiFi Analyzer which will tell you if there is any interference in the 2.4Ghz or 5Ghz bands, and will recommend which channels to use. I'm in a fairly rural area so there's next to no interference on either band, but in busier suburbs and downtown city locations I've seen 2.4Ghz completely saturated.
Welcome To SNBForums
