BosseSwede
I have a newly installed fiber connection at my summer cottage.
I subscribe to a 250/250 Mbps service.
I have installed my old home router (RT-AC68U) there when I visited the site after fiber was activated.
The site is 100 km away so not easily accessed.
The router is configured with OpenVPN connection to my home LAN and routing is set up to allow bi-directional access between the two networks.
This works fine functionally, but I have discovered a speed problem...
The measured down/up speed to the Internet does not comply to the 250/250 Mbps I have subscribed to.
Download is always at 250 but upload varies wildly over the day to sometimes ridiculously low values in single digit Mbps levels.
See attached graph below.
I have complained to my ISP and they have forwarded the complaint to the fiber network provider, which required me to make some specific tests only possible on location:
- Attach a computer directly to the fiber interface
- Disconnect anything else connected there (the router)
- Make speed tests against several test providers
- Report results
Again I saw these problems using my Windows laptop as test device and reported.
Then I reconnected the router and also connected a RaspberryPi4 directly to the fiber interface where I had the laptop during testing.
This RPi4 is configured to run Ookla Speedtest CLI from cron at 30 min interval and log the result to a logfile.
It also reports the log to me so I can follow the progress.
The fiber network provider has replied to my ISP and said (translated by me):
Due to the distance to the cottage it is not a simple task to rearrange the physical connections...
QUESTIONS:
1) Is it possible to configure the Asus RT-AC68U router to NOT generate (or transfer) the pause frames they complain about?
2) Is it really possible that the "pause frames" they complain about can cause such problems on a different LAN connection on the fiber interface (it has 4 Ethernet connectors)?
The current log graph covering a month of measurements looks like this:
- Report results
The other "device" I have now re-attached on LAN1 is the Asus router and behind that are another HP Linux computer and a slave Access Point (another Asus router).We see that there are a number of "pause frames" coming from a device on the LAN1 connection.
Ask the customer to test with a single device connected at a time to exclude the possibility of a local problem source.
Return if the problem appears on devices connected alone to the CPE.
QUESTIONS:
