Asus RT-AC68U VLAN
Amatheas
Hello,
I have been searching the web for a while now and I can't find a a solution how to use VLAN's on my router.
Basically the idea configure one eth port to a different VLAN than the others. The one port is for server and the others are for basic home networking. I want to remove the connect-ability between the server and my home network.
The thing is, I haven't found a straight answer is VLAN-tagging possible with the stock firmware?
I found my way to the linux cli and started digging. Bu using ifconfig I got the list of all interfaces, but I can't make heads or tails about which interface is the port 4. Busybox gives me the command vconfig which to my knowledge can be used to tag interfaces with VLAN id's, but it requires the interface name, I kinda hit a wall there too.
So I need help to complete my desired topology.
-Ama
