Feb 4 19:22:00 vpnserver1[7837]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 12 2020
Feb 4 19:22:00 vpnserver1[7837]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.03
Feb 4 19:22:00 vpnserver1[7838]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Feb 4 19:22:00 vpnserver1[7838]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 4 19:22:00 vpnserver1[7838]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Feb 4 19:22:00 vpnserver1[7838]: Diffie-Hellman initialized with 2048 bit key
Feb 4 19:22:00 vpnserver1[7838]: TUN/TAP device tun21 opened
Feb 4 19:22:00 vpnserver1[7838]: TUN/TAP TX queue length set to 100
Feb 4 19:22:00 vpnserver1[7838]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Feb 4 19:22:00 vpnserver1[7838]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Feb 4 19:22:00 vpnserver1[7838]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Feb 4 19:22:00 vpnserver1[7838]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Feb 4 19:22:00 vpnserver1[7838]: UDPv4 link local (bound): [AF_INET][undef]:41700
Feb 4 19:22:00 vpnserver1[7838]: UDPv4 link remote: [AF_UNSPEC]
Feb 4 19:22:00 vpnserver1[7838]: MULTI: multi_init called, r=256 v=256
Feb 4 19:22:00 vpnserver1[7838]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Feb 4 19:22:00 vpnserver1[7838]: Initialization Sequence Completed
Feb 4 19:31:59 vpnserver1[10823]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 12 2020
Feb 4 19:31:59 vpnserver1[10823]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.03
Feb 4 19:31:59 vpnserver1[10824]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Feb 4 19:31:59 vpnserver1[10824]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 4 19:31:59 vpnserver1[10824]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Feb 4 19:31:59 vpnserver1[10824]: Diffie-Hellman initialized with 2048 bit key
Feb 4 19:31:59 vpnserver1[10824]: TUN/TAP device tun21 opened
Feb 4 19:31:59 vpnserver1[10824]: TUN/TAP TX queue length set to 100
Feb 4 19:31:59 vpnserver1[10824]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Feb 4 19:31:59 vpnserver1[10824]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Feb 4 19:31:59 vpnserver1[10824]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Feb 4 19:31:59 vpnserver1[10824]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Feb 4 19:31:59 vpnserver1[10824]: UDPv4 link local (bound): [AF_INET][undef]:41067
Feb 4 19:31:59 vpnserver1[10824]: UDPv4 link remote: [AF_UNSPEC]
Feb 4 19:31:59 vpnserver1[10824]: MULTI: multi_init called, r=256 v=256
Feb 4 19:31:59 vpnserver1[10824]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Feb 4 19:31:59 vpnserver1[10824]: Initialization Sequence Completed
Feb 4 22:24:12 vpnserver1[24227]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 12 2020
Feb 4 22:24:12 vpnserver1[24227]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.03
Feb 4 22:24:12 vpnserver1[24228]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Feb 4 22:24:12 vpnserver1[24228]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 4 22:24:12 vpnserver1[24228]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Feb 4 22:24:12 vpnserver1[24228]: Diffie-Hellman initialized with 2048 bit key
Feb 4 22:24:12 vpnserver1[24228]: TUN/TAP device tun21 opened
Feb 4 22:24:12 vpnserver1[24228]: TUN/TAP TX queue length set to 100
Feb 4 22:24:12 vpnserver1[24228]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Feb 4 22:24:12 vpnserver1[24228]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Feb 4 22:24:12 vpnserver1[24228]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Feb 4 22:24:12 vpnserver1[24228]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Feb 4 22:24:12 vpnserver1[24228]: UDPv4 link local (bound): [AF_INET][undef]:41067
Feb 4 22:24:12 vpnserver1[24228]: UDPv4 link remote: [AF_UNSPEC]
Feb 4 22:24:12 vpnserver1[24228]: MULTI: multi_init called, r=256 v=256
Feb 4 22:24:12 vpnserver1[24228]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Feb 4 22:24:12 vpnserver1[24228]: Initialization Sequence Completed
Feb 4 22:28:05 vpnserver1[25693]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 12 2020
Feb 4 22:28:05 vpnserver1[25693]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.03
Feb 4 22:28:05 vpnserver1[25694]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Feb 4 22:28:05 vpnserver1[25694]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 4 22:28:05 vpnserver1[25694]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Feb 4 22:28:05 vpnserver1[25694]: Diffie-Hellman initialized with 2048 bit key
Feb 4 22:28:05 vpnserver1[25694]: TUN/TAP device tun21 opened
Feb 4 22:28:05 vpnserver1[25694]: TUN/TAP TX queue length set to 100
Feb 4 22:28:05 vpnserver1[25694]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Feb 4 22:28:05 vpnserver1[25694]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Feb 4 22:28:05 vpnserver1[25694]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Feb 4 22:28:05 vpnserver1[25694]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Feb 4 22:28:05 vpnserver1[25694]: UDPv4 link local (bound): [AF_INET][undef]:41067
Feb 4 22:28:05 vpnserver1[25694]: UDPv4 link remote: [AF_UNSPEC]
Feb 4 22:28:05 vpnserver1[25694]: MULTI: multi_init called, r=256 v=256
Feb 4 22:28:05 vpnserver1[25694]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Feb 4 22:28:05 vpnserver1[25694]: Initialization Sequence Completed
Feb 4 22:31:21 vpnserver1[27138]: OpenVPN 2.4.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 12 2020
Feb 4 22:31:21 vpnserver1[27138]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.03
Feb 4 22:31:21 vpnserver1[27139]: NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Feb 4 22:31:21 vpnserver1[27139]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Feb 4 22:31:21 vpnserver1[27139]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Feb 4 22:31:21 vpnserver1[27139]: Diffie-Hellman initialized with 2048 bit key
Feb 4 22:31:21 vpnserver1[27139]: TUN/TAP device tun21 opened
Feb 4 22:31:21 vpnserver1[27139]: TUN/TAP TX queue length set to 100
Feb 4 22:31:21 vpnserver1[27139]: /sbin/ifconfig tun21 10.8.0.1 pointopoint 10.8.0.2 mtu 1500
Feb 4 22:31:21 vpnserver1[27139]: /etc/openvpn/ovpn-up tun21 1500 1622 10.8.0.1 10.8.0.2 init
Feb 4 22:31:21 vpnserver1[27139]: /sbin/route add -net 10.8.0.0 netmask 255.255.255.0 gw 10.8.0.2
Feb 4 22:31:21 vpnserver1[27139]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Feb 4 22:31:21 vpnserver1[27139]: UDPv4 link local (bound): [AF_INET][undef]:41067
Feb 4 22:31:21 vpnserver1[27139]: UDPv4 link remote: [AF_UNSPEC]
Feb 4 22:31:21 vpnserver1[27139]: MULTI: multi_init called, r=256 v=256
Feb 4 22:31:21 vpnserver1[27139]: IFCONFIG POOL: base=10.8.0.4 size=62, ipv6=0
Feb 4 22:31:21 vpnserver1[27139]: Initialization Sequence Completed
