AlgonquinWolf
Setup
Router: Asus RT-AC86U Asuswrt-Merlin 384.15 Provider: Teksavvy (over Rogers Cable)
My standard config (has been set up for over 2 years)
Hitron CDA3-20 Modem -> Grandstream ATA HT502 -> RT-AC86U -> Lan Clients (wired computers, wifi enabled computers, wired IOT devices and wifi IOT)
Note: The ATA is set up in bridge mode. The AC86U handles the DHCP assignments for the network. The AC86U has a different WAN IP than the HT502
Issue
My internet frequently and randomly gets disconnected. When that happens the router shows no internet connection. The devices remain connected to the router, but no internet. The ATA stays functional (I can make and receive calls).
Connectivity doesn't come back automatically,I get internet back by either rebooting the router or rebooting the ATA (whens its part of my config) , either seems to work.
Troubleshooting so far
Assuming it was the ATA, I took the ATA out of the picture, so my config was Hitron CDA3-20 Modem -> RT-AC86U -> Lan Clients but I still had the random almost daily drop of internet.
I recently installed Asuswrt Merlin 384.15 hoping that would resolve the issue, but no luck.
I can't seem to find anything abnormal in the router logs, and I can't seem to find any determining factor triggering this drop. I have checked the router usage, memory and temperature, and all are in reasonable limits.
The router power supply is directly plugged into a APC UPS.
Any suggestions would be greatly appreciated. Thanks
Issue
